| | LinkBack | Thread Tools |
| | #3 |
| The Trisexual Join Date: Oct 2003 Location: The asshole of the USA, New Jersey Age: 22
iTrader: 0 / 0% Ride: 2007 Civic, 1995 Jeep Grand Cherokee
Rep Power: 123 | You [b]can[b/] bore to 84 mm but the sleeves are gonna be pretty damn thin, I would reccomend about 82mm like 97CTR said. It also depends on what you're doing, if it's going to be a relatively stock motor where you're not beating on it all the time, 84 is reasonable and will work fine. If your going FI, I wouldn't go over 82 on stock sleeves. It's early and if I said something stupid and wrong just ignore it. |
| | #5 | |
| Admin with a big stick Join Date: Sep 2002 Location: Dallas / Fort Worth, TX Age: 32
iTrader: 0 / 0% Ride: 2003 S2000
Rep Power: 392 | Quote:
| | #6 |
| Member | werd ... depends on what your setup is compression, depends wether your going na boosted or nitrous ....... as far as bore'n it if your going turbo you might as well bore and sleeve it if your going all motor id bore it 81 and be safe |
| | #7 | |
