I have a LS/VTEC that I would like to build up to about 225 HP naturally aspirated, but I would like to do this safely and reliably.
I am interested in knowing how much internal upgrades do I need such as with the valve train, pistons, rods, bolts, cams, etc. Also ECU, ignition and fuel upgrades and tuning options play a big part as well. Would appreciate all your feedback on the best approach to take. Thanks |
#2 | |
Check the setup listed in my signature. Once I do the head work, put in some real cams and valvetrain, get a header and some exhaust, I plan on putting down @ 210 to the wheel. That's a 1.9 litre LS/VTEC @ 11.6:1. (I know my sig says 11.8:1 but it ended up being closer to 11.6:1, those are just the numbers endyn stated) I also don't really have shit for engine management, just a crappy VAFC, but I am saving for AEM, FAST, or Motec, I haven't decided yet. (And I may spend the money on some ITBs anyway )85 mm bore would make much more torque, but I didn't want to spend the money on sleeves. I have also heard some bad stuff about sleeves, but that's a whole other story.... I actually get my car back this week sometime, then I have to break it in for 500 miles because I have a new clutch too, so I will post dynos in about 2 weeks. I expect my motor to put down around 180 once i get it broken in, with stock exhaust manifold, stock exhaust, ctr cams, stock head, and a shitty tune. 225 hp to the wheel is much harder than 225 to the flywheel, but it's very do-able. 85mm with 12:1 compression and some decent cams and you are pretty much there..... __________________
Latest project - 1 fucking fast 99 SI
i am also building an allmomtor lsvtec @ the moment, what can I also do to increase the displacement with out having to change sleeves?
92' DA9 JDM B16 **<u>Garage Sale</u>** OBD1 Dizzy -- VERY CLEAN!! $75+Shipping DA OEM Headlights -- Great Cond. No Cracks! $70+Shipping DA Gauge Cluster -- $60+Shipping DC Complete Wiper Motor -- $25+Shipping DA Complete Cruise Control -- $20+Shipping DA GSR Driver Side Motor Mount w/ Energy Suspension Insert -- $50 <u>GREAT DEAL!!!</u> 93 DA Cherry Red Taillights -- $75+Shipping |
#5 |
why EMS FAST or MOTEC, you just picked the three most expensive ones. Why not Hondata, Uberdata (free), Crome
225whp, 84-85mm sleeves with over 12:1 compression. Pick up some big cams, good tuner __________________
97 ex coupe Wire tuck in progress.... |
#6 | |
Because despite what you think, hondata, and uberdata (i know nothing of crome) are still just piggyback systems, while the 3 I named are REAL standalone engine managment units. Not to mention I get really good prices on AEM and FAST, although Motec would be a little pricey for me. I will probably go with the AEM system just for the ease of use. Especially since I just got a KILLER deal on a set of ITBs..... ![]() __________________
#7 | |
#8 | |
[/b][/quote] ![]() __________________
#9 |
i dont know about "putting down serious power" requiring you to use "motec"...in the Forced induction world (the easier world
) i dont know how many 200 300 and 400 horsepower hondas i see running hondata systems...theres nothing wrong with a piggy back..its just with all motor..u gotta watch what the fuck your doing...with boost...all u gotta do is have a strong bottom end or sick tuning really.__________________
91 Crx Si : Mini me swap - SOLD. 91 Crx HF: N/A LS - SOLD. 93 Cx hatch : LS turbo - SOLD. 94 Integra RS - Bone stock. Soon to be boostin.... |
#10 | |
[/b][/quote] So i dont get it mike, are you saying you think hondata ETC. ETC. are fine for this type of a situation and that you understand why MR hondata did the switch OR that you think hondata are gonna be fine for this praticular setup? Im gonna have to say hondata etc etc are gonna be able to run this 220hp LSvtec fine, and even better then fine. And other then that i was always under the impression that hondata wasint a piggy back set up nor uber or chrome, as far as i know you chip the ECU and then you tune the chip, so i dont see anything piggy back about. See the whole idea about the VAFC is that the ECU is taking commands from it thus making it a piggy back, a secondary priority even though the ECU makes it take presidence. When you chip and tune the ECU there is no secondary system telling the ecu how to run the car, the ECU's main chip has the program in it. If im wrong correct me. __________________
97 Acura integra GS-R AEM cold air intake Apex-i N1 cat back Dc header best 1/4 15.4 --------------------------- |
#11 |
Retired OG
Ride: Integra, Tahoe
if you've got the money and you haven't started buying parts yet... then bump the ls/vtec and spring for a k-series. a stock internal k-series with only intake, header, exhaust and hondata is puttin' down 220 whp and runnin' 12's in full interior eg's. if you think that you might want more out of all motor after you get your fully built b-series done... look into the k. 220 whp... stock.
Kyle I. Collins, PmD. |
#12 |
yeah when the hell did Hondata EVER become a "piggyback" system. Hondata is a standalone engine management system!! There are plenty of 200, 300, 400HP allmotor and boosted engines on Hondata. and uberdata
and __________________
#13 | |||
OK Jeff, consider yourself corrected. :P Hondata IS a piggyback system in the sense of the word, your ECU is still there. The AEM unit, as well as the fast, motec and a few others actually REPLACE your ECU making it a ..... (drumroll please) .... Stand Alone enging management unit. <!--QuoteBegin-97CTR@Jun 13 2005, 07:19 AM yeah when the hell did Hondata EVER become a "piggyback" system. Hondata is a standalone engine management system!! There are plenty of 200, 300, 400HP allmotor and boosted engines on Hondata. and uberdata and [/quote] Can't argue with the K series except for the $$$$$. But yes, people run 12s like it's their job with a stock K series in an EG. It should come with a fucking guaranty or something... "Run 12s or your money back!" Hondata = piggyback. Do some reserch, call some real tuners. I'm not saying it isn't MORE than capable of running a 220 hp LS/VTEC, I'm saying I want a real EMS. __________________
#14 | ||||
Hondata = piggyback. Do some reserch, call some real tuners. I'm not saying it isn't MORE than capable of running a 220 hp LS/VTEC, I'm saying I want a real EMS. [/b][/quote] Yeah but because AEM replaces the hole unit does not mean that another isint. Im gonna say hondata still isint a piggy back, but that aem is a more advanced form of a stand alone engine management. You guys are using the word piggy back too loosly. And are gonna cause misconception.I have personly chipped and worked with the ECU's so i like to think i have a good grasp on all of it. __________________
#16 | |
![]() Shouldn't that be that you have chipped one ecu? And didn't you mess that one up? I'll post more about this thread later, but Im at work and had to call your ass out on this one. |
#17 |
Alright someone has the wrong idea of a piggyback. A piggy back system changes the input signals that the stock ecu receives from the engine. Thus fooling the ecu to beleive that different conditions exist within the engine. Just because a hondata unit is attatched to the ecu and it looks to be riding along like a "piggyback" does NOT make it a piggyback system. Do some research, call some real tuners :P
#19 | |
Because despite what you think, hondata, and uberdata (i know nothing of crome) are still just piggyback systems, while the 3 I named are REAL standalone engine managment units. Not to mention I get really good prices on AEM and FAST, although Motec would be a little pricey for me. I will probably go with the AEM system just for the ease of use. Especially since I just got a KILLER deal on a set of ITBs..... ![]() [/b][/quote] you are simply amazing __________________
94 Honda Accord, jdm h22 swapped daily driver 04 cbr600rr fun toy 95 toyota tacoma, lifted winter truck |
#20 | |
![]() Shouldn't that be that you have chipped one ecu? And didn't you mess that one up? I'll post more about this thread later, but Im at work and had to call your ass out on this one. [/b][/quote] I fixed it, it was a cold joint. And no, i have since chipped two more...... smart ass __________________
#21 | |
#22 | |
#23 |
Direct from Hondata's website. They even state themselves that it is NOT a standalone system.
"What does Hondata do? Hondata modifies standard Honda engine computers (ECUs), adding features and expanding the capabilities of the ECU (e.g. for forced induction). Several products are offered, including tunable systems, tuning software and datalogging software. Does Hondata cover my vehicle? Hondata covers most vehicles from 1992 up, but some vehicles require the use of an adapter harness and/or OBDI ECU swap. Use the application wizard to see what products are available for your vehicle, or view applications by ECU, applications by engine or applications by vehicle Why should I buy a Hondata system instead of a replacement standalone computer? Nothing runs a Honda engine as well as Honda ECU. End of story." Quote from Hondatech debate of AEM VS Hondata "you can ask for the long list of features that the AEM EMS provides over Hondata, most of which do not appeal to the average honda turbo user, like traction control (not 100% functional yet) and antilag, integrated boost control with closed loop feedback, ability to fire multiple sets of injectors, control outputs for things like methanol and nitrous injection (both switched output and PWM "analog" style), separate nitrous fuel mapping for dry setups, multiple o2 sensors, EGT fuel trim per cylinder, fuel trim in general per cylinder, auto tranny convertor lockup, integrated datalogging (without laptop), direct fire ignition control (1 coil per cylinder), knock retard (just like J&S) which can add fuel as well as retard timing, integrated 2step rev limiter. " Debate 1 __________________
#24 | |
