how does a normal piston look???
Old 03-12-2004, 06:30 PM   #1
m2slsvtec671 is off the scale
just wondering how does a normal piston loook like?? cause like two weeks ago.. my friend just got his car running.. of rebuild and adding internal.. new pistons builded bottom end..head worrk.. etc.. and two days ago we were changing his spark plug and we peek in just to look at the pistons... it was black... and it looks wet..?? it looked like it had oil or i dont really know what it was.??? but is that normal.. ???? how is the piston suppose to look...like??? and his car is running good no check engine light... oh and its a ls vtec too... we just freaking out... thanks!!!
Menace 2 Society!!!!! Rides That Excite!!!!
www.ridesthatexcite@groups.msn.com
www.geocities.com/m2sridesthatexcite
m2slsvtec671 is offline   Reply With Quote
Old 03-12-2004, 06:40 PM   #2
turbo4dr is off the scale
you might get a little oil past the rings as they seal but it should stop after it is broken in. Did you break in the motor with non-synthetic oil?
turbo4dr is offline   Reply With Quote
Old 03-12-2004, 07:27 PM   #3
Slammed90Lude is an unknown quantity at this point
Send a message via AIM to Slammed90Lude
if you're worried that the rings didn't seal properly do a leak down test and see what's up
Slammed90Lude is offline   Reply With Quote
Old 03-12-2004, 07:28 PM   #4
naw he use this cheap as oil from exxon... for the break in period ..... so yeah he was freaking out... he thinks his motor gonna give up... he was already giving up and shit...thanks..
Old 03-13-2004, 02:03 AM   #5
oh and his also smoking out white smoke??? good or bad...?? how can we fix that problem?>???
Old 03-13-2004, 07:29 AM   #6
Ride:  01 is300, 05 s2000, 03 rx300
pills_PMD is an unknown quantity at this point
Send a message via AIM to pills_PMD
did you reuse the headgasket lol?
pills_PMD is offline   Reply With Quote
Old 03-13-2004, 08:04 AM   #7
naw its brand new ... everything is new......
ls block with pr3 piston question???? jpangeles Engine Building 11 07-06-2004 03:10 PM
Whats normal EGT for turbo?? gettocrx Forced Induction 4 05-10-2004 07:12 PM
How to Compute the Compression Ratio of a motor pissedoffsol General Tech Articles 0 01-12-2004 12:41 AM
Caliper Piston eyesonlybob General Tech and Maintenance 11 10-12-2003 11:05 PM
Will It Fit? Piston Rings? Liquidblaze Engine Building 0 03-13-2003 01:23 PM
