How to tell what size rod bearings
Old 03-10-2009, 08:12 PM   #1
Conan The Hondarian
wikedeye's Avatar
Ride:  1993 Honda Civic Dx Coupe
Rep Power: 28 wikedeye is a splendid one to beholdwikedeye is a splendid one to beholdwikedeye is a splendid one to beholdwikedeye is a splendid one to beholdwikedeye is a splendid one to beholdwikedeye is a splendid one to behold
Send a message via AIM to wikedeye
Default How to tell what size rod bearings
I am going to buy eagle rods for a b16a and I am not sure how to determine which bearings I will need. I know how to tell what size I need for the crank, but not for the rods. Any advice?
Originally Posted by 99sidude View Post
yes silicone lubricant worked great on my shaft. highly recommend.
XBL: Wikedeye
wikedeye is offline   Reply With Quote
Old 03-10-2009, 08:41 PM   #2
Green on the scene.
MthaFuknGreen's Avatar
Ride:  Fuckin Prelude Si 2.1l 1990
Rep Power: 70 MthaFuknGreen has a brilliant future
Send a message via AIM to MthaFuknGreen myspace
purchase a micrometer set and get to measuring.
fuckin mustangs..
Originally Posted by kdizzyvtec View Post
ill do that then dick
Go Green
^go listen.
its me.
MthaFuknGreen is offline   Reply With Quote
Old 03-10-2009, 09:08 PM   #3
Conan The Hondarian
wikedeye's Avatar
Do you just measure the inside of the rod, then the crank? Then take the difference and do what? How much space should be left over between the bearing and the rod. A little more info would be helpfull.
XBL: Wikedeye
Old 03-10-2009, 09:22 PM   #4
Custom User Title
eastbxc's Avatar
Ride:  90 civic hatch
Rep Power: 29 eastbxc is a splendid one to beholdeastbxc is a splendid one to beholdeastbxc is a splendid one to beholdeastbxc is a splendid one to beholdeastbxc is a splendid one to beholdeastbxc is a splendid one to beholdeastbxc is a splendid one to behold
Originally Posted by wikedeye View Post
A little more info would be helpful.
Agreed. I am interested myself.
"the dude abides"
myEF
XBL-seabiscut88
eastbxc is offline   Reply With Quote
Old 03-10-2009, 09:32 PM   #5
Green on the scene.
How to use a micrometer
for a decent set of inside and outside micrometers, itll probably run you at least $2500, so maybe you could go to a shop and have them help you out.
but yeah, use an inside mic to measure the the rod and make sure to measure taper and and out of round as well and then use an outside mic to measure the cranks rod journals, measuring taper and out of round on that too. then determine the oil bearing clearance specs by either buying the manual for your engine or im sure someone could give you a good range to work with.
youll probably just need to measure the rod journals on the crank because im assuming that wherever youre buying the rods from would have the specs and measurements.
or you could just find the specs for the crank in your engine and assume that it hasnt been worn down to much..
Honda Engine Specs
fuckin mustangs..
Go Green
^go listen.
its me.
Old 03-10-2009, 09:56 PM   #6
Conan The Hondarian
wikedeye's Avatar
Thanx for your help. I also found these videos on youtube which are helpfull.
XBL: Wikedeye
Old 03-10-2009, 10:37 PM   #7
Green on the scene.
reading a standard micrometer can be a pain in the ass to learn, but once you do its easy.
cliff notes for reading a standard mic-
whatever size mic it is = the first number. example, 1-2" mic reading should have a 1.xxxx.
whatever number you can see on the sleeve, is the second number. example: 4. so far the reading is 1.4xxx.
each line after the number is worth 25 thousandths.
say its two lines past the 4, .025 + .025 = .050.
the reading so far is 1.450x
then add how ever many lines on the thimble there is and ad that to the .050.
say its 23 lines up, each line is worth .001.
so the measurement is 1.473x.
if there is a vernier scale on it, then it can measure to the ten-thousandths place and you only need it if the line on the thimble doesnt line up perfectly with the index line on the sleeve.
if the line doesnt line up, you just look for whatever line lines up perfectly with any of the lines on the vernier scale and tack that number in the place of the last x.
metric mics are soo much easier.
fuckin mustangs..
Go Green
^go listen.
its me.
Old 03-11-2009, 06:47 AM   #8
Custom User Title
eastbxc's Avatar
Someone rep green for me it says I need to spread it around first. Thanks for the great info.
"the dude abides"
myEF
XBL-seabiscut88
Old 03-11-2009, 11:37 AM   #9
Boosted ls/vtec ohh yeah!
boostin4fun's Avatar
Ride:  EM1 EBP boosted ls/vtec, EM1 EBP Daily Driver
Rep Power: 18 boostin4fun has a spectacular aura aboutboostin4fun has a spectacular aura about
This is a great resource when selecting factory honda bearings.
Honda Bearing color to thickness chart for everyone who loves using OEM bearings - Honda-Tech
My build threads:
http://hondaswap.com/engine-building...c-build-84953/
http://hondaswap.com/engine-building...inished-92905/
I offer ecu socketing/chipping, tuning, swaps, and builds. PM me for details and pricing.
boostin4fun is online now   Reply With Quote
Old 03-11-2009, 06:18 PM   #10
Green on the scene.
i just remembered how to measure the oil clearance!
lol
plastigage.
fuckin mustangs..
Go Green
^go listen.
its me.
Old 03-12-2009, 09:08 AM   #11
Conan The Hondarian
wikedeye's Avatar
I hit him with some rep.
XBL: Wikedeye
Old 03-14-2009, 05:12 PM   #12
since the machine shop spec'd my block and crank out and said I'd be good with just OEM green bearings, I went with ACL standards... used plastigauge and was set.
90 Integra Sedan
B20V 225 / 153
Old 03-15-2009, 01:06 AM   #13
I have used acl's in my last 3 builds with great success also. I have heard many people trash talk them but half of those people have not used them personally or dont know how to build and tune shit in the first place.
My build threads:
Old 03-15-2009, 03:49 PM   #14
Conan The Hondarian
wikedeye's Avatar
I am sure greens would work, but I would rather have the best fit possible. I am just going to have the machinist tell me when I get the block honed, because I dont really want to buy all the tools I would need to properly check it myself
XBL: Wikedeye
Old 03-15-2009, 04:38 PM   #15
Jizared97's Avatar
Ride:  97 ex coupe, 89 240sx
Rep Power: 44 Jizared97 has a brilliant futureJizared97 has a brilliant futureJizared97 has a brilliant futureJizared97 has a brilliant futureJizared97 has a brilliant futureJizared97 has a brilliant futureJizared97 has a brilliant futureJizared97 has a brilliant futureJizared97 has a brilliant future
Send a message via AIM to Jizared97 myspace
Remember, machine shops can sometimes make mistakes. Its always good to check everything multiple times.
Jizared97 is offline   Reply With Quote
Old 03-15-2009, 09:44 PM   #16
Green on the scene.
definitely would be cheaper.
anyone can make mistakes, but the machine shop probably has more experience with measuring stuff accurately.
fuckin mustangs..
Go Green
^go listen.
its me.
Old 03-15-2009, 10:10 PM   #17
Conan The Hondarian
wikedeye's Avatar
They do sometimes make mistakes, but plastigauge is cheaper then micrometers. Even if I buy what they tell me and they are wrong I can check it and get a bearing or two where needed. Still cheaper then micrometers.
XBL: Wikedeye
Old 03-15-2009, 10:13 PM   #18
Green on the scene.
but plastigage is for checking bearing oil clearance.
fuckin mustangs..
Go Green
^go listen.
its me.
Old 03-15-2009, 10:16 PM   #19
Conan The Hondarian
wikedeye's Avatar
Yeah I know. If the shop tells me get X size bearing and I put in with the plastigauge then I will know if the clearance is to little or to great. Then I will know what size I actually need.
XBL: Wikedeye
Old 03-15-2009, 10:18 PM   #20
Green on the scene.
do you know how to use plastigage?
fuckin mustangs..
Go Green
^go listen.
its me.
Old 03-15-2009, 10:19 PM   #21
Conan The Hondarian
wikedeye's Avatar
Yes, why does what I am saying seem wrong.
XBL: Wikedeye
Old 03-15-2009, 10:21 PM   #22
Green on the scene.
nope. just making sure.. lol
youre lucky bearing sizes decrease in hundredths.
fuckin mustangs..
Go Green
^go listen.
its me.
Old 03-15-2009, 10:28 PM   #23
Conan The Hondarian
wikedeye's Avatar
The size of the bearing is what effects the oil clearance correct so plastigauge is the proper way to check if the bearing is the right size. I am right about this arent I.
XBL: Wikedeye
Old 03-15-2009, 10:30 PM   #24
Green on the scene.
the size of the bearing and the size of the crankshaft.
fuckin mustangs..
Go Green
^go listen.
its me.
Old 03-15-2009, 10:33 PM   #25
Conan The Hondarian
wikedeye's Avatar
Yeah so if I put the bearing into the rod and connected the rod to the crankshaft with a piece of plastigauge, and it doesnt measure to the right clearance then I would know that the bearing is the right or wrong size
XBL: Wikedeye
bore size? piston size? arroshiz Forced Induction 7 05-27-2005 12:30 AM
wheel size vs. tire size shfaster Wheels / Suspension / Tires / Brakes 9 07-26-2004 05:13 PM
where to buy main bearings and rod bearings KFBhonda Engine Building 13 01-13-2004 12:13 PM
Injector Size And Turbo Size? slow hatch Forced Induction 1 04-15-2003 04:49 AM
Rod Bearings & Main Bearings Slimtadder Engine Building 11 01-08-2003 05:19 AM
