i can get an ls tomorrow for 200$
Old 02-15-2006, 10:25 PM   #1
JDMBurna is off the scale
ok, i know this guy with a totalled 96 integra ls. is t boned in the rear. he will sell it to me for 400$ and my girls brother is willing to put half cause he wants the seats and front end. i would take the ls motor tranny harness and ecu. my question is this. how much better is the gs-r block compared to the ls block? if i use the ls block with the gsr head, will that be a good setup if i change the internals and go for 400 horses? or would it be cheaper in the long run for me to just stick with the gsr swap(wich costs around 3k)?i mean if im gonna rebuild the bottem end of the gsr block anyway then would there even be a difference wich block i use or is the gsr one stronger?i know the gsr head has better air flow but i could just get one on ebay for like 500-600$. how hard is it to swap it onto the ls block? anyway let me know what you recomend
JDMBurna is offline   Reply With Quote
Old 02-15-2006, 10:43 PM   #2
and yea i know i would need to get the ls vtec conversion kit. basically i wanna know. if im going for 400 whp...can i reach that goal for less money if i go with the ls block and gsr head? or am i better off just paying the extra money and going with the full gsr motor
Old 02-15-2006, 11:57 PM   #3
tip
tip is an unknown quantity at this point
<div class='quotetop'>QUOTE(JDMBurna @ Feb 15 2006, 10:43 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
just my 2 cents ..........but if you are going to rebuild the bottom end anyways then i would get the ls for 200 bones and rebuild it. No need to spend three grand on a gsr swap then pay the $$$ for the rebuild to. And further more i would go all ls......rebuild bottom end, full head job, and turbo it.
tip is offline   Reply With Quote
Old 02-16-2006, 12:46 AM   #4
CrazyAzn's Avatar
CrazyAzn is off the scale
but the gsr bottom end is alot better in my opinion, you get the block girdle, oil squiters and a slightly shorter stroke which isnt as hard on the revs. along with an oil cooler, which i dont even know how good it works, along with all the gsr goodies such as oil pump, water pump. i got my gsr bottom end for 300. if you wanted to you could also build up a gsr motor for cheaper than buying the complete block if you get the head adn bottom end seperate, like 300 for the bottom end and maybe 4-500 for the head. but its all up to you, but for 2 bills i would get that car ne ways.
hope i helped,
kyle
89 EF build: Poorman's ITR
95 GSR bottom end, .25over b16 pistons Pr3
Zealautowerks compression = 11-8-1
ARP head studs, Stock head gasket
S2 Pro series IM, w/ Hondata intake gasket
Holley 68mm throttle body
ITR 4-1 header, w/ 2.5 in magna flow exhaust ( sounds niceeeee btw)
kteller 2.5 mandrel bend kit.
PnP b16 head w/ dual valve springs and ITR cams
Milled about .030
AEM hybrid CAI
Running obd1 w/ p28 tuned on chrome
Made 178 at churches w/ 2in exhaust and dc 4-2-1 header w/ 2 in collector.
CrazyAzn is offline   Reply With Quote
Old 02-16-2006, 08:12 AM   #5
tip
<div class='quotetop'>QUOTE(CrazyAzn @ Feb 16 2006, 12:46 AM) Quoted post</div><div class='quotemain'>
hope i helped,
kyle
[/b][/quote]
that's exactly why i said to go with the ls....$200.00 START OUT PRICE...!!!!
your way at least $800.00 before you start your build not to mention that vtec prices are a lot higher then the non vtec counters.....!
Old 02-16-2006, 08:29 AM   #6
my name is Dale
erebunicrx's Avatar
Ride:  cbr 929rr
erebunicrx is an unknown quantity at this point
Send a message via AIM to erebunicrx
just buy it b/c its a killer deal. then reaserch and layout a plan of what you want to do.
erebunicrx is offline   Reply With Quote
Old 02-16-2006, 09:38 AM   #7
ok thanks for the input. i was gonna buy it anyway cause it was so cheap even if i just want to resell it for me. but i dont know i might rebuild it i have to look into it more though
Old 02-16-2006, 09:53 AM   #8
my name is Dale
erebunicrx's Avatar
Ride:  cbr 929rr
where are you located maybe you can double your money real quick
Old 02-16-2006, 10:08 AM   #9
lawrence,mass. i see them selling the complete swap on ebay for like 750$ +shipping so im thinking i ca sell it for like 500$ in the streets. hey if oyur interested i would really like that crx shell lol
Old 02-16-2006, 11:27 AM   #10
Führer Mod
eg6sir's Avatar
Ride:  Le Car
eg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond repute
Send a message via AIM to eg6sir Send a message via Yahoo to eg6sir myspace  FaceBook
yea.. just buy it.. you can always resell it and make a little $$
eg6sir is offline   Reply With Quote
Old 02-16-2006, 06:54 PM   #11
CrazyAzn's Avatar
thats what im saying, but that shit ne ways, and if ne thing just resale it. you can get at 200 for an ls real quick. . . not to mention you can part out the rest of the car and sell lil things here and there. you can sell almost any part off a honda and make money off of it.
