FüK-VTEC
Ride: 07 Nissan Frontier, 90 CRX Si, 06 ZX6R racebike, chopped-out 02 Yamaha V-Star
So I scored a spare GSR intake manifold for damn near nothing a few weeks ago, and I'm finally getting around to porting it. I'm going for something like the DH racing manifold:
![]() Only thing I'm going to do different is make the dividers a little lower, maybe a half-inch or so...I was also thinking about maybe staggering them so that the one closest to the TB is shorter/lower, and they rise up by a millimeter or 2 as they go away from the TB... The red is a general outline of what I'm taking out...not exact, but close. ![]() ![]() ![]() ![]() Thanks to ImageShack for Free Image Hosting Also, I know Erick Aguilar used 2 spacer thingies on his manifold...anyone have any idea why? Obviously it works, seeing as he ran 9's on a more or less stock GSR manifold....but what's the science behind it? ![]() Comments? Please don't give me any 'Just buy a skunk2 manifold' bullshit. I'm not losing any money, and I want to see how much power can be made with a stocker. Comments? Suggestions? |
#3 | |
yeah i always thought you would want the runers themselves to be ported not between the pieces.
who asked you? Quote:
sir I w/ 00 head/itr intake + s1=$900 full d series turbo kit(turbo pistons rods pipes bov fmic oil pan) $1100 |
#5 |
I am not going to tell you right or wrong or what to do. I am merely going to state what works in the physical universe.
1.) Velocity>flow. The faster the velocity into the cylinder the more air that will cram into the space for combustion. 2.) The intake runners should be in a smooth conical shape tapering down to the intake running. 3.) Polishing the intake will do nothing for you except waste time and money. Especally at this point of the intake because fuel has not even been injected into the air stream yet. Even after the point at which fuel is injected, a rough surface is better to keep the fuel in suspension longer. |
#7 | ||
Blah blah blah....
2.)What you said makes no sense really grammatically, but I kind of almost agree with what I think you are thinking. You are trying to generalize a way to increase the velocity in the runners, but you forget as the velocity and therefore dynamic velocity increases, your static pressure is going down the tube, and you have to find a compromise somewhere that satisfies your power goals. The dual stage runners are there for a purpose, and they do a good job for the most part. 3.) Polishing is not a waste of time and money otherwise people wouldn't do it. It cuts down on pressure recovery losses in the plenum an runners, annd ultimately comes down to greater engine efficiency. Now, it has more to do with the actually design of the IM than the wall finish, but it still offers gains, and if you are a DIY'er, all it costs you is time, for research and the actual work. Just make sure to rough up the last bit of the IM before the flange, to induce a little turbulence. You definitely don't want fuel pooling up on the walls. Will... I don't know if I would cut out the entire dual stage IAB's unless you are just working to increase the top end. The gsr is known for its midrange power, mostly due to that dual stage intake. I'd just open up the holes a bit more, and leave the dual stage in if I were you. Since you got it for next to nothing, you could test different stages of IM porting, opening the holes up bit by bit, testing it as you go, and see what happens each time you modify it. That would be a fun way to learn about what works and what doesn't. As for Aguilar's setup, I would imagine that the spacers are more or less tuning the length of the runners for his setup. They also allow a bit more volume after the TB, allowing a larger column of air to be crammed into the port, it seemed to be a mass-momentum-total pressure thing to me, but that's only a guess. __________________
#8 | |||
Sorry. I assumed that from the statements that the others were making. Quote:
1.) This is not always true. Like at the top end of your power band. You'll want both. You don't want to bottleneck your top end for the sake of low end response. But it depends on what you are building for. 2.)What you said makes no sense really grammatically, but I kind of almost agree with what I think you are thinking. You are trying to generalize a way to increase the velocity in the runners, but you forget as the velocity and therefore dynamic velocity increases, your static pressure is going down the tube, and you have to find a compromise somewhere that satisfies your power goals. The dual stage runners are there for a purpose, and they do a good job for the most part. 3.) Polishing is not a waste of time and money otherwise people wouldn't do it. It cuts down on pressure recovery losses in the plenum an runners, annd ultimately comes down to greater engine efficiency. Now, it has more to do with the actually design of the IM than the wall finish, but it still offers gains, and if you are a DIY'er, all it costs you is time, for research and the actual work. Just make sure to rough up the last bit of the IM before the flange, to induce a little turbulence. You definitely don't want fuel pooling up on the walls. Will... I don't know if I would cut out the entire dual stage IAB's unless you are just working to increase the top end. The gsr is known for its midrange power, mostly due to that dual stage intake. I'd just open up the holes a bit more, and leave the dual stage in if I were you. Since you got it for next to nothing, you could test different stages of IM porting, opening the holes up bit by bit, testing it as you go, and see what happens each time you modify it. That would be a fun way to learn about what works and what doesn't. As for Aguilar's setup, I would imagine that the spacers are more or less tuning the length of the runners for his setup. They also allow a bit more volume after the TB, allowing a larger column of air to be crammed into the port, it seemed to be a mass-momentum-total pressure thing to me, but that's only a guess. [/quote] 1.) Yes velicoty and flow are both wanted at ALL rpm ranges. So the opening at the choke point (which will be the true bottleneck because it should be the smallest) needes to be a size that will allow enough air pass so that it not choke the engine. 2.) Perhaps I should have worded it as "The intake runners should be in a conical shape tapering down to the intake port." Please explain the principles of the static pressure and what it is needed/used for? 3.) Please explain the theory of pressure recovery loss. |
#9 |
CHP has done this back a while ago, Loses BIG TIME low end power, didn't pick up till 7000 in a built GSR running 14.2 compression. dynoed at 203 horse, then slapped on stock gsr, ran 254 horse, BIG DIFFERENCE!
1991 Honda CRX Si, JDM B18C GSR Swap, AEBS Manifold, CTR Pistons, DPR ITR Stage 5 Head, Skunk2 stage 2 Cams, Skunk2 cam gears, AEM V2, ANR Header, Greddy E-Manage, ACT 6 puck clutch, AEM fuel rail, Eagle Rods, Type R tranny, Enjo axles, Runs 12.8 ALL MOTOR! |
#10 | ||
Blah blah blah....
#11 |
The Trisexual
Ride: 2007 Civic, 1995 Jeep Grand Cherokee
i assume it could be true but I doubt it.
I say go for it. __________________
DO NOT PM ME WITH TECH QUESTIONS!!! Current Rides 1992 Chevy S-10 Ext. Cab Previous 1992 Civic DX Hatch = 1994 B18B1 Turbo Rebuilt Garrett .60/.48 T3, log style mani and DIY downpipe, DSM 440's, kteller IC piping, JRC Intercooler, Home Depot style oil lines, HKS BOV, Crome Tuned, 253whp 1994 Civic VX Hatch, 1992 b18a1 swap 1993 Civic CX Hatch, 2000 B18b1 |
#12 | ||
Blah blah blah....
2) Static pressure is basically the manifold pressure, or pressure not affected by flow velocity. For an N/A application, it is near the ambient air conditions, that is, close to 14.67 psi, or 1 atm. But, you can pressurize moving air by slowing it down gradually, and this is what intake plenums are designed to do. It isn't a lot of pressure, but any pressurization is going to allow more air to be crammed into the engine ata given time. more air = more power potential. so you design the IM to gradually slow the air down to gain static pressure. On the other hand, you want dynamic pressure as well, because that is what allow the cylinders to continue filling after the cylinder reaches BDC. So you basically want both, but where you choose to optimize your powerband will affect the balance of static and dynamic pressure. 3) Static + Dynamic = Total Pressure. Pressure recovery is just a measure of efficiency of the component the air mass is flowing through, in this case, the IM. Say you measure the total pressure at the entrance and exit of the IM, you are going to have less total pressure at the exit due to flow disruptions, poorly designed turning in the flow, etc. Pressure Recovery just = Total Exit Pressure/ Total Entrance Pressure. Smoothing the walls through most of the manifold will cut down skin friction drag in the manifold, increasing the overall efficiency of the mmanfold. But like was mentioned before, turbulence is a good thing near and in the port, because it helps to further atomize the fuel-air mixture, whichis good for other obvious reasons. But polishing the manifold will allow the total pressure entering the port to be higher. Now, this isn't saying you'll gain 2342374234 hp by doing it, but if you were racing professionally, every extra .5 hp gain is worth the extra work that goes intoo the manifoold design/modification. For Will's case, it probably isn't, unless he want to spent the extra 15 or so hours it would probably take to properly polish it. It's not practical to do it for a street driven car, and most people don't want to pay extra to have a machine shop do it. But it isn't a waste of time. It's cool that you ask questions, show that you actually are interested in how things work, and not just interested in the end result, namely going fast. I am inspired constantly with new things to try on my car, but until I have the money, a lot of those experiments won't happen. I just research the material in the meantime. Good luck with the project will, and document your progress, so we can hear about it later. ![]() __________________
#13 | |
#14 | ||
Blah blah blah....
#15 | |
2) Static pressure is basically the manifold pressure, or pressure not affected by flow velocity. For an N/A application, it is near the ambient air conditions, that is, close to 14.67 psi, or 1 atm. But, you can pressurize moving air by slowing it down gradually, and this is what intake plenums are designed to do. It isn't a lot of pressure, but any pressurization is going to allow more air to be crammed into the engine ata given time. more air = more power potential. so you design the IM to gradually slow the air down to gain static pressure. On the other hand, you want dynamic pressure as well, because that is what allow the cylinders to continue filling after the cylinder reaches BDC. So you basically want both, but where you choose to optimize your powerband will affect the balance of static and dynamic pressure. 3) Static + Dynamic = Total Pressure. Pressure recovery is just a measure of efficiency of the component the air mass is flowing through, in this case, the IM. Say you measure the total pressure at the entrance and exit of the IM, you are going to have less total pressure at the exit due to flow disruptions, poorly designed turning in the flow, etc. Pressure Recovery just = Total Exit Pressure/ Total Entrance Pressure. Smoothing the walls through most of the manifold will cut down skin friction drag in the manifold, increasing the overall efficiency of the mmanfold. But like was mentioned before, turbulence is a good thing near and in the port, because it helps to further atomize the fuel-air mixture, whichis good for other obvious reasons. But polishing the manifold will allow the total pressure entering the port to be higher. Now, this isn't saying you'll gain 2342374234 hp by doing it, but if you were racing professionally, every extra .5 hp gain is worth the extra work that goes intoo the manifoold design/modification. For Will's case, it probably isn't, unless he want to spent the extra 15 or so hours it would probably take to properly polish it. It's not practical to do it for a street driven car, and most people don't want to pay extra to have a machine shop do it. But it isn't a waste of time. It's cool that you ask questions, show that you actually are interested in how things work, and not just interested in the end result, namely going fast. I am inspired constantly with new things to try on my car, but until I have the money, a lot of those experiments won't happen. I just research the material in the meantime. Good luck with the project will, and document your progress, so we can hear about it later. ![]() [/b][/quote] I can understand why you would want to slow the incoming charge down in order to better fill the cylinder? Why wouldn't you want the incoming mixture to continue flowing as fast as possible increasing its velocity? It seems counter productive to slow the mixture down to increase the pressure because the end result is power not pressure. You need to speed it up (velocity) to create more power. Yeah and ask more questions! |
#16 | ||
Blah blah blah....
. As the air is slowed down, the air molecules are forced closer together by collision with decelerating molecules in front of them. You want the flow to be as steady as possible going into the head, meaning no flow reversion. That is where velocity comes into play, because you want the air to have enough momentum to continue to fill the cylinders, but not to the point of where the velocity is so high that it drops the pressure to below ambient. You don't want that because density varies directly with pressure (perfect gas law), and the lower the density, the less power you make. Velocity in this case is not the only thing that affects power, but it is a factor. Anyway, I'll stop cluttering up this thread... ![]() __________________
#17 | |
FüK-VTEC
So I'm gonna take me a die grinder and waller out that there intake manifold. Mm-hmm. |
#18 | ||
Blah blah blah....
So I'm gonna take me a die grinder and waller out that there intake manifold. Mm-hmm. [/b][/quote] __________________
#19 |
Admin with a big stick
Ride: 2003 S2000
#21 | |
raise the dead. This is very good info. __________________
<a href=\'http://www.hondaswap.com/forums/index.php?act=module&module=gallery &cmd=user&user=25607&op=view_album& album=107\' target=\'_blank\'>PICTURES: Type R Stuff/ B-Series Parts for Sale</a> |
#22 |
Stylus DJ Extraordinaire
Will whatever happened with this? Just wondering? How did it go?
DC Squad Member # 0631 I used to have my rides in this section but there are too many thieves out there trying to jack. I HATE THIEVES |
#24 |
he probably got wasted and forgot about the thread, you know what the cool kids do!
j/p. __________________
90 Integra Sedan B20V 225 / 153 I DO NOT answer tech questions via PM. Use the forums!!! |
#25 |
FüK-VTEC
Lol...I'm lazy, and still haven't gotten around to going up to the foundry and doing anything :P
