i have a b16 in my 95 hatch. when i drive my car, sometimes my speedometer dont work properly and sometimes it works perfectly. when the speedometer does work, my car feels like shit. sometimes when im driving, as i accellarate (when the speedometer goes crazy) i can see the rpm drop to about 0rpm and it makes my car bogg and not move. so i accellerate slow and shift into other gears to just get it moving.
i have no idea whats going on, please help with any suggestions!! i just changed cap and rotor from a gsr distributor. stock usdm p30 ecu running a stock jdm b16. cels i have are 10, 20, 41. |
RETIRED
the first thing to do is to fix your CEL's. you have wiring problems up the ass.
10- IAT Sensor (Intake Air Temperature) probably not wired right... 20- Electrical Load Detector probably not wired right... 41- Primary Oxygen Sensor - Heater bad sensor? didn't do a 4-wire conversion if needed? |
#6 |
find the cels and fix them first, then run it, check your alternator, and see if it's getting power, could be numerous things, and yes it can react like that.
#8 |
i bet it is your alternator, has happend to me 2 times. take it to any auto place to test it.
2005 Mitsubishi Lancer Evolution 8 2004 BMW 325i 2000 Mercedes Benz ML 430 1994 Honda Civic Del Sol VTEC (race kaa) |
#10 | |
no, i'll check in my helms for you tomorrow.
#12 | |
