I Think i have a Timing Issue
Old 02-20-2006, 09:37 PM   #1
Rep Power: 8 poops87 is off the scale
I need help timing my 88 ZC i need to find the base timing i think the timing is too retarded and i have advanved my dizzy all the way and i don't know which direction to turn my crank to the front of car or the fire wall to put the range of my dizzy right
and if anyone knows the exact degrees the timing should be i would name my first kid after you!!!
poops87 is offline   Reply With Quote
Old 02-20-2006, 10:13 PM   #2
HS Troll...And Mod
reikoshea's Avatar
Ride:  2001 Honda S2000
myspace
almost every honda is +16. J-O-S-H (naw jus playin)
Anime Informant
reikoshea is offline   Reply With Quote
Old 02-21-2006, 11:26 AM   #3
Thanks but what if its a Girl? JOshina , or Joshani , or joshani-kwa lol
Old 02-24-2006, 01:08 PM   #4
Rep Power: 18 nfn15037 is off the scale
<div class='quotetop'>QUOTE(poops87 @ Feb 20 2006, 09:37 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
Uh, timing light much?
Friends Don't Let Friends Apex Early
nfn15037 is offline   Reply With Quote
Old 02-27-2006, 01:59 PM   #5
jlicrx's Avatar
<div class='quotetop'>QUOTE(poops87 @ Feb 20 2006, 07:37 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]is this a DOHC ZC engine? if so, with the top bolt on the distributor in the center of the slot, the ignition timing should be real close to 16 degrees - turn top of distributor toward firewall to advance, toward radiator to retard - if it is not real close to 16 with top bolt in center of slot, your intake camshaft is probably off one tooth
ZCspeed Racing
Old 02-27-2006, 04:04 PM   #6
<div class='quotetop'>QUOTE(nfn15037 @ Feb 24 2006, 01:08 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
[/b][/quote]
Oh yeah i don't have timing marks For 16 degrees probably should have told you guys that, that is the only reason i asked for timing degrees so i can set it with a gun that i can dial the degrees
Old 02-28-2006, 03:56 AM   #7
HS Troll...And Mod
reikoshea's Avatar
myspace
yeah, and if the baby is a girl, you can use my middle name....Ryan. Its interchangable.
Anime Informant
