| | LinkBack | Thread Tools |
| | #1 |
| The Seniorest Member.... Join Date: Nov 2002 Location: El Paso, TX now, originally from Fresno, CA Age: 28
iTrader: 0 / 0% Ride: 93 Civic CX w/ B16A ,T3/T4 Turbo
Rep Power: 31 | I was wondering if an Integra Type-R cap bridge will fit on a B18B1 block. I heard it can be done with a little modification, but... Thanks for everyone's help!!!! |
| | #2 |
| Admin with a big stick Join Date: Sep 2002 Location: Dallas / Fort Worth, TX Age: 32
iTrader: 0 / 0% Ride: 2003 S2000
Rep Power: 391 | The girdle? If you're talking about the crank girdle, it'll go on- but you have to machine the main caps to fit or use the main caps from an ITR. |
| | #4 |
Rep Power: 31 | That's why I wanna use it... I saw an article awhile ago about how to make this work, does anyone have a link to this? P.S. I called it a "cap bridge" because acuraautomotiveparts.org calls it that. I thought it was called a crank girdle too. |
| | #5 | |
| Senior Member | Quote:
All you have to do to make it work is get the main caps from a GSR/ITR block and install them w/the girdle and have it align bored. | |
| | #6 | |
Rep Power: 391 | Quote:
There are a number of aftermarket girdles available too. | |
| | #7 |
Rep Power: 31 | I tried ordering main caps for my H23, and Honda told me that I couldn't just order them, I'd have to buy the whole block. Where do you order just the main caps from? What companies make aftermarket girdle's? Thanks everyone!!! |
| | #9 |
| thistownsucks... | nobody has mentioned that if you choose to use a girdle you MUST use.. ITR/GSR oil pan, windage tray and oil pickup...on either OEM or aftermarket girdles. so add that into the budget if you wanna go that route. matt |
| | #10 | |
| | #11 | |
| thistownsucks... | Quote:
[/b][/quote] standard b series (b16/b18/b20) oil pans will not fit over that added girdle..must be GSR/type R | |
