yes
LS vtec build http://hondaswap.com/auto-multi-medi...t=lsvtec+build New GSR build 2009 http://hondaswap.com/auto-multi-medi...5/#post1400802 |
definetly,, you are reducing rotational mass which directly affects hp. there is no question.,
[font=Impact][b][i]HOOKUPS IMPORT TEK allmotor crx 10.89@124.9mph ALLMOTOR cleanest swaps in so cali guaranteed!!!! 909-373-RACE JDM HONDA PERFORMANCE PARTS AND ENGINE SWAPS!!! |
yes, itr fly is 15lbs b16 fly is 21-22lbs (can't remember which)
2005 Mitsubishi Lancer Evolution 8 2004 BMW 325i 2000 Mercedes Benz ML 430 1994 Honda Civic Del Sol VTEC (race kaa) |
#5 |
Gonzo Scientist
Ride: 96 Ford Escort
I'm pretty sure flywheel only changes response/revving. But if you meant that it affects how the hp is used, you're correct. But they dont add hp as far as I knew. Just like lighter wheels.
Tommythecat had many a story to tell, but it was a rare occasion, such as this, that he did. _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ http://www.woostercollective.com/ |
#6 | |
#7 | |
#8 | |
[/b][/quote]or i could be wrong? :P that would be nice if it is, makes my flywheel instantly lighter!! __________________
#9 |
it depends on the year of the ITR Swap.
and going with a lighter flywheel is not always good. otherwise we would all be running 9lb toda/spoon flywheels. i believe in 96 JDM itr's had 12-13lb flywheels. as far as the rest, they are like 15-16lbs. B16a flywheels are around 18lbs...but can be resurfaced and lightened safely to 14lbs... i'd resurface what you have and shed just a few lbs from it...nothing drastic... you'll loose too much torque...which isn't a great compromise even if you gain more top end. __________________
<a href=\'http://www.geocities.com/coker_boy/honda.html\' target=\'_blank\'>The Green Machine</a> |
#10 |
ACTUALLY by reducing rotating mass you will make more hp to the wheels example: dyno a car with 17" heavy wheels, then dyno with 13"vx lightweight wheels. i have personally seen a 9hp difference from just the weight of the wheels. anyways i always recommend a lightened fly wheel, you will sacrifice a little torque but gain rev response as well as hp.
#12 |
in some cases i would agree depending on your weight of the vehicle however keep in mind that to a certain point especially for a street car to much torque will only hurt you(traction problems) hondas as far as drag racing goes make most of their gain in the second half of the 1/4 mile. this is long after hp has taken over. but if your car is heavy then yes more torque is a good i dea.
| Is the H22A swap worth it in an Accord? I say yes | HONDAPITSTOP | HYBRID -> BA-BB /CA-CD | 20 | 03-28-2008 01:02 PM |
| Handy tip for R&R flywheel and crankpulley | BlueShadow | Engine Building | 5 | 07-30-2004 07:15 PM |
| ZC Clutch and Flywheel Questions | allmotord16rex | HYBRID -> ED-EF / DA | 4 | 08-18-2003 11:10 PM |
| ZC Clutch and Flywheel Questions | allmotord16rex | HYBRID -> ED-EF / DA | 1 | 08-14-2003 09:00 PM |
| Flywheel And Crankshaft Lightening And... | saturn_boy96 | Engine Building | 3 | 05-25-2003 05:08 PM |
