Low Temp Thermostat
Old 06-03-2003, 11:35 AM   #1
Rep Power: 14 sol2nr is off the scale
i have a jdm b16a in my del sol. I plan on running a 35shot within the next two months, getting hondata s200b also by that time, and a JRSC by may 04. I want to get a low temp thermostat, but what temp should I get? I don't want to waste the money on a spoon one, so what company should i get thats not very expensive? Is there any drawback to lowering the thermo temp besides my heat not being as hot?
thanks,
-ROB
sol2nr is offline   Reply With Quote
Old 06-03-2003, 04:49 PM   #2
RETIRED
pissedoffsol's Avatar
Ride:  Electric Scooter
a motor is designed to run at a cerain temp... hondas, 185 degrees. why try to lower it to 165?
lower motor temp does NOT equal colder air to the intake or a better burn. it just makes your radiator work twice as hard to keep it cool.
Old 06-03-2003, 05:19 PM   #3
i was thinking that myself. I was thinking that the ECU reads engine temp and changes things according to that, and messing with the thermostat would create problems, but then how or why does spoon and mugen and other companies have low temp thermostats?
Old 08-26-2003, 11:00 PM   #4
Rep Power: 16 omega11855 is off the scale
i am also curious my car was in a accident and i got a radiator out of it i opted for a fluidyne for a little extra $ so i was thinking i could prob bear to drop 5or 10 degrees on the thermostat temp and still be good do you know if that would be good since i have added compresion to the motor?
"Girls are like cars u can have as many as you can afford but you can only drive one at a time"~Me
<a href=\'http://www.jzperformance.com\' target=\'_blank\'>Jz own meee</a>
omega11855 is offline   Reply With Quote
Old 08-27-2003, 01:22 AM   #5
Rep Power: 17 kingwilly is off the scale
i got the mugen thermoswitch and thermostat in my b16..runs cool...you need to get both,cuz if you dont get the fan thermoswitch then the fan wont come on earlier and if you just get the thermostat then...nevermind dont wanna explain im in outer space
kingwilly is offline   Reply With Quote
Old 08-27-2003, 03:39 AM   #6
or u could just run switch to the fan so it is always on when the car is on like my friend h4h4h4h4hh4h4
&quot;Girls are like cars u can have as many as you can afford but you can only drive one at a time&quot;~Me
Old 08-27-2003, 04:07 AM   #7
ya i had to do that on a jetta i used to own..
Old 08-28-2003, 12:43 AM   #8
just run your stocker man,,,trust me...
Milan
13.3@103 MT's &amp; Gutted
-Project 5 - Motor A (???)
Old 08-28-2003, 12:51 AM   #9
Slammed89Integra's Avatar
Ride:  2007 Scion TC, 2005 Suzuki GSX-R 600
Rep Power: 155 Slammed89Integra has a reputation beyond repute
Slammed89Integra has a reputation beyond reputeSlammed89Integra has a reputation beyond reputeSlammed89Integra has a reputation beyond reputeSlammed89Integra has a reputation beyond reputeSlammed89Integra has a reputation beyond reputeSlammed89Integra has a reputation beyond reputeSlammed89Integra has a reputation beyond reputeSlammed89Integra has a reputation beyond repute
Send a message via AIM to Slammed89Integra myspace
Doesn't that kill his power at all?
I know when my fan kicks on it kills the power, like the voltage goes down and the car shakes like mad but then again I am running dual FAL's.
When this is all over I think we should get an apartment together.
Slammed89Integra is offline   Reply With Quote
Old 08-28-2003, 03:06 AM   #10
B happy
92b16vx's Avatar
Ride:  dohc 95 egg
Rep Power: 186 92b16vx has a reputation beyond repute
92b16vx has a reputation beyond repute92b16vx has a reputation beyond repute92b16vx has a reputation beyond repute
Because those companies car are designed to be run much longer, and much faster, than your daily driver.
95 CX|B16A2
XBL | binary xj0hnx | Halo 3
Old 08-28-2003, 11:28 AM   #11
so there is no point in getting a 5 degree or 10 degree lower thermostat if u have raised the compression of your motor? and are running a better then stock radiator?
Old 08-28-2003, 11:48 AM   #12
B happy
92b16vx's Avatar
Ride:  dohc 95 egg
I am using the stock replacment fanswitch and thermostat, and a fluidyne, even when I am beating my motor like it stole my daughters virginity, it doesn't make the temp gauge move.
95 CX|B16A2
Old 08-28-2003, 01:41 PM   #13
Member of the 20 nut club
E_SolSi's Avatar
Rep Power: 527 E_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond repute
E_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond repute
im running the same setup (fluidyne radiator, stock fan, switch, thermostat)
i can do 30min runs on a road course fully abusing the VTEC lobes and my temps dont move
МОΛΏΝ ΛΑΒΈ
Old 08-28-2003, 03:50 PM   #14
spoon and mugen make those kind of parts to pretty much rip us off, if you do want a lower then do get a lower one from discount auto for like 7 bucks but please dont' spend your cashish '60 bucks' on some thermostat from japan.
Like I said before use your stocker.
Milan
Old 08-28-2003, 05:51 PM   #15
ok so just out o curiousity under what conditions would a daily driver need a lower temp thermostat and what is stock temp on a type-r to begin with?
Old 08-29-2003, 12:30 AM   #16
E_SolSi's Avatar
never
not sure
МОΛΏΝ ΛΑΒΈ
Old 08-29-2003, 03:29 AM   #17
nice hahahahah
so even 5degrees wouldnt be worth it
i remember reading somewhere that the stock temp sensor gauge is crappy and that the temp can move a large amount before actually showing anything on the factory gauge so have you ever tried to verify with an autometer that ur temp isnt moving that drastically
Old 08-29-2003, 03:34 AM   #18
B happy
92b16vx's Avatar
Ride:  dohc 95 egg
Originally posted by omega11855@Aug 29 2003, 08:29 AM
nice hahahahah
I live in Germany and drive on the autobahn, I take daily 120mph trips to other towns, for extended periods of time, on like i said, the stock therm. and fan. no problems what so ever.
95 CX|B16A2
Old 08-29-2003, 01:35 PM   #19
that makes me feel better 120 fuck on a b16 u must be at like 6500
Old 08-29-2003, 01:41 PM   #20
E_SolSi's Avatar
i run road course with the same cooling setup (fluidyne rad, stock everything else) im repeatedly acclerating from 60 - 120 for about 30 min for each of 4 runs (2 hours total) every time i go..... i have never had any coolant issues
МОΛΏΝ ΛΑΒΈ
h22 temp issues driver1 HYBRID -> BA-BB /CA-CD 17 09-13-2006 11:06 AM
WTF? Where's the thermostat? sohcslammer General Tech and Maintenance 4 10-13-2003 10:58 PM
Temp. Guage going up/down erratically RFHOMI2U General Tech and Maintenance 2 09-23-2003 08:01 PM
low temp thermostat or OEM? seanjuan General Tech and Maintenance 6 09-11-2003 04:49 PM
Coolant temp sensor issues LS/VTecEF9 General Tech and Maintenance 2 07-30-2003 07:08 AM
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
