ls block with pr3 piston question????
Old 06-22-2004, 02:12 AM   #1
Rep Power: 12 jpangeles is off the scale
i have a 1990 ls integra block and have pr3 jdm piston? i want to use the pr3 piston in the block i just noticed that pr3 is 1.6 liter and ls integra is 1.8...do i need a oversized rings for this cituation or i can used the rings from the pr3?
jpangeles is offline   Reply With Quote
Old 06-22-2004, 02:15 AM   #2
Blah blah blah....
MikeBergy's Avatar
Rep Power: 49 MikeBergy is on a distinguished road
Send a message via AIM to MikeBergy
You can use the pr3 rings, since they are the same bore size. The stroke of the motor is what makes the motor 1.6 or 1.8 liters. Just realize you are bumping compression quite a bit. You also need to use the ls rods. Pr3 rods are too short.
-1991 Integra, lots of goodies in an otherwise stock looking motorp; ITR front brakes.
-Xenocron programmable ecu w/datalogging port, LM-1 wideband, and Moates Ostrich are tuning tools of choice.
RIP 2005 Red Yamaha R6
www.m24x.com - Rocket Motorsports: For more technical engine discussions...
Radar will bounce off of a ride that is shiny and you keep clean.
Please don't PM me with tech questions. Use the forums!
MikeBergy is offline   Reply With Quote
Old 06-22-2004, 02:15 AM   #3
Member of the 20 nut club
E_SolSi's Avatar
Rep Power: 569 E_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond repute
same bore (81mm)
the extra .2L is from the stroke
МОΛΏΝ ΛΑΒΈ
E_SolSi is online now   Reply With Quote
Old 06-22-2004, 02:16 AM   #4
E_SolSi's Avatar
doh!
he beat me to it
МОΛΏΝ ΛΑΒΈ
Old 06-22-2004, 10:41 AM   #5
Angry
ohh thanks guys for ur help and ill be using the ls rods for my engine set up
Old 06-22-2004, 01:04 PM   #6
your compression ratio will be around 10.9:1 or so...
you can use the LS rods...
90 Integra Sedan
B20V 225 / 153
Old 06-22-2004, 04:19 PM   #7
Admin with a big stick
Calesta's Avatar
Ride:  2003 S2000
More like 11.1, but it's close enough.
Old 06-22-2004, 06:15 PM   #8
That all depends on the head gasket thickness and the head he uses...
Stock LS head w/
1 layer HG 11.69:1
2 layer HG 11.39:1
3 layer HG 11.10:1
B16/B17/ITR Head w/
1 layer HG 12.30:1
2 layer HG 11.96:1
3 layer HG 11.63:1
B18C head w/
1 layer HG 10.89:1
2 layer HG 11.18:1
3 layer HG 11.48:1
90 Integra Sedan
B20V 225 / 153
Old 06-22-2004, 06:43 PM   #9
actually this set up is for ls/vtec...ls block with a gsr head....what do u mean 3 layer gasket? is that i have to put 3 gasket so i can race my compression to the higher one?
Old 06-22-2004, 07:01 PM   #10
Honda uses a 3 layer headgasket... you can change hte compression of a motor by putting a thinner head gasket in... such as a 2 or 1 layer.
Simply put the head gasket has 3 layers to it... a 2 layer has 2, a 1 layer has 1. When you get the head closer to the block it raises the compression, the further away from the block you are the high the compression.
90 Integra Sedan
B20V 225 / 153
Old 07-06-2004, 04:03 PM   #11
Rep Power: 0 calligra is off the scale
Send a message via MSN to calligra
I was looking at an LS/Vtec setup with those pistons I think you are around 11.6 : 1
that is with OEM gasket
B18 Block and B16 Head.
Calli
1991 Acura Integra GS (soon LS/VTEC)
calligra is offline   Reply With Quote
Old 07-06-2004, 04:10 PM   #12
LS Block and Head w/PR3 pistons nets an 11.1:1 w/ 3 layer head gasket
LS block and B16 head w/PR3 pistons nets an 11.63:1 w/ 3 layer head gasket
http://www.c-speedracing.com/howto/c...c/compcalc.php
90 Integra Sedan
B20V 225 / 153
