LS Crank and Rods
Old 08-25-2008, 02:19 AM   #1
Rep Power: 0 blwnsmke is infamous around these partsblwnsmke is infamous around these partsblwnsmke is infamous around these parts
Default LS Crank and Rods
I am running a LS crank and LS Eagle H beams in my new motor setup. Im going to be using a B18c5 block. My question is, aren't the b16 and b18 aftermarket pistons all interchangable?? The reason Im asking is because I want to know if I can run these pistons they are for a B18c. Im running a ITR head also..
eBay Motors: WISECO 94-01 ACURA INTEGRA GSR B18C TURBO PISTONS SET (item 220249597716 end time Sep-21-08 10:14:03 PDT)
blwnsmke is offline   Reply With Quote
Old 08-27-2008, 08:56 PM   #2
Grand High Wizard
tartymctang2357's Avatar
Rep Power: 10 tartymctang2357 will become famous soon enoughtartymctang2357 will become famous soon enough
Send a message via AIM to tartymctang2357
the ls rods are, at least in stock form are a little wider then the gsr rods at the small end, i'm not sure about the aftermarket ones, but to fit any type r or gsr piston on to a ls rod about 1mm of material needs to be removed from each side of the ls rod to have the piston fit properly.
Though you might want to check the width of your rod, if you ended up buying them and they needed modification a machine shop could shave them down for a small price.
ls rod small end witdth is 19.9mm and a gsr rod small end width is 17.9mm
tartymctang2357 is offline   Reply With Quote
Old 08-27-2008, 09:33 PM   #3
Ahh i see what your saying. The actual LS rod end that hooks to the wrist pin? I am running the Eagle H Beams so Im not sure if they are the same and stock or what?? So in order for my to run those pistons Ill most likely have to have my rods shaved down a little?
Old 08-28-2008, 02:48 AM   #4
Grand High Wizard
most likely yes, but you might want to either measure the rod ends with a micrometer or ask the manufacturer, if you do need to shave them down a tad its not that expensive to have a machine shop do but again you might want to ask around i've never dealt with eagle rods before only know from my previous ls-vtec expierence with stock rods
CR-VTEC? crank and rods? gettocrx Engine Building 13 10-26-2006 01:59 PM
fs: b17 crank rods and pistons lshatchcx18 Parts: For Sale/Trade/Wanted 9 02-21-2006 01:48 AM
B20 crank, rods and other misc erebunicrx Parts: For Sale/Trade/Wanted 6 03-05-2005 03:48 PM
f22's crank, rods, pistons into the H22 brian11to1 Engine Building 6 10-21-2003 05:30 PM
Best Rods Ls Crank? lsvtec hatch00 HYBRID -> EG-EK / DC 9 03-27-2003 01:08 PM
