LS Turbo. good trans????
Old 02-28-2008, 07:56 PM   #26
The Kicker of Elves.
Blanco's Avatar
Rep Power: 217 Blanco has a reputation beyond repute
Blanco has a reputation beyond reputeBlanco has a reputation beyond reputeBlanco has a reputation beyond reputeBlanco has a reputation beyond reputeBlanco has a reputation beyond reputeBlanco has a reputation beyond reputeBlanco has a reputation beyond reputeBlanco has a reputation beyond reputeBlanco has a reputation beyond repute
Originally Posted by jtornado View Post
Well I never said the GSR won't give me better than the LS tranny but the way you make it sound is that the GSR has better acceleration no matter what HP. lol thats how you word it, too me of course. Wait is that true though???
Shorter gears are always faster. Traction should be taken care of elsewhere.
Now, if we're talking about a high horsepower, purpose built, drag car. The transmission should be designed so you're redlining your last gear right as you cross the finish line. Again, traction should be taken care of elsewhere.
Think about this. You can easily pick up 25% more acceleration through gearing alone.
Don't misinterpret what I say.
Originally Posted by The Secrets of Body Language
93% of communication is done through body language.
Originally Posted by http://humanresources.about.com/od/interpersonalcommunicatio1/a/nonverbal_com.htm
One study at UCLA indicated that up to 93 percent of communication effectiveness is determined by nonverbal cues. Another study indicated that the impact of a performance was determined 7 percent by the words used, 38 percent by voice quality, and 55 percent by the nonverbal communication.
Originally Posted by Shawn Pelton
It's not good to be a drummer unless you got some bad motherfucker up inside you.
Blanco is offline   Reply With Quote
Old 02-28-2008, 09:06 PM   #27
jtornado's Avatar
Ride:  92 Civic Si
Rep Power: 0 jtornado is infamous around these parts
Ya but in my opinion I would rather have more traction with less accel than less traction with more accel. I don't wanna be spinning through all gears before I even get traction at the finish line lol (I'm just theoretically speak) Plus Ill still get the benefit of fast accel and traction with the LS tranny for my setup. Which is why I didn't want the GSR. 60 trim with .48 A/R w/ 3" ex will spool pretty fast anyway so it doesn't matter really, if I wanted fast accel.
jtornado is offline   Reply With Quote
Old 02-28-2008, 09:32 PM   #28
The Trisexual
92civicb18b1's Avatar
Ride:  2007 Civic, 1995 Jeep Grand Cherokee
Rep Power: 121 92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of
Send a message via AIM to 92civicb18b1 Send a message via Yahoo to 92civicb18b1
I had rebuilt a 42/48 and upgraded to a 60 housing, I made good numbers and was fully spooledby 3k rpm.
DO NOT PM ME WITH TECH QUESTIONS!!!
Current Rides
=I love this truck
2007 Civic
=Not sure what the future holds for this
Previous
1992 Civic DX Hatch
= 1994 B18B1 Turbo
Rebuilt Garrett .60/.48 T3, log style mani and DIY downpipe, DSM 440's, kteller IC piping, JRC Intercooler, Home Depot style oil lines, HKS BOV, Crome Tuned,
253whp
1994 Civic VX Hatch, 1992 b18a1 swap
1993 Civic CX Hatch, 2000 B18b1
92civicb18b1 is offline   Reply With Quote
Old 02-28-2008, 10:13 PM   #29
jtornado's Avatar
Ride:  92 Civic Si
Ya that can all depend on your setup too. What is considered as a big turbo, do you guys go buy the a/r or trim????
Old 02-28-2008, 10:16 PM   #30
Blanco's Avatar
What part of "traction should be taken care of elsewhere" is confusing you?
If you shut up for three seconds and actually listen, instead of skimming and continually talking out of your ass, you might learn something.
Old 02-28-2008, 10:29 PM   #31
you get the BRAKE
LS_VTEC's Avatar
Ride:  99 YZF-R6
Rep Power: 40 LS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to behold
Shorter gears = more torque multiplication. More torque multiplication = faster rev's. Its a small gear driving a much larger gear. Who care's anyway? Just get the gsr or the ls or a b16 transmission for that matter.
eg hatch (jdm b16) sold
1999 Yamaha YZF R6 (modded)
http://hondaswap.com/engine-building...ow-pics-102486 sold
LS_VTEC is offline   Reply With Quote
Old 02-29-2008, 12:00 AM   #32
jtornado's Avatar
Ride:  92 Civic Si
Ya I understand what you mean about traction should be taken care of elsewhere. It doesn't matter what tranny you will be using cause you will get the same traction out of all of them most likely. Your telling me don't worry about the tranny and start thinking about suspension and tire sizes?????
Old 02-29-2008, 10:04 AM   #33
Blanco's Avatar
First, thank you for starting to think.
Depending on power levels, higher gears will induce more wheel spin due to the higher torque multiplication...what LS/V just said. So, you have to take steps to cure the problem. These steps include traction bars, proper suspension setup, limited slip differentials (LSDs) and good tires...meaning, over $100/ea.. You can choose to run longer gearing and higher power, but you're ultimately putting more stress on the engine and still inducing wheel spin with the higher power level. At the purpose-built level, your transmission gearing should be designed so you're hitting redline in your top gear right as you cross the finish line...in other words, really short gearing. If you're building your engine for the street, you can either take the best OEM compromise (the GSR transmission) or build your own transmission with an LS fifth gear in a B16 transmission for cruising and top speed. The former is significantly less expensive.
This is yet another reason why I tell people not to build race engines for street cars.
Old 02-29-2008, 11:37 AM   #34
jtornado's Avatar
Ride:  92 Civic Si
Lol well another reason why I choose the LS tranny is because thats the only tranny I know I can get my hands on. Thanks for the Info Blanco
Old 02-29-2008, 12:15 PM   #35
Blanco's Avatar
You should've just said that in the first place.
Old 02-29-2008, 12:32 PM   #36
HS RA
eg6sir's Avatar
Ride:  Le Car
Rep Power: 225 eg6sir has a reputation beyond reputeeg6sir has a reputation beyond repute
eg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond repute
Send a message via AIM to eg6sir Send a message via Yahoo to eg6sir myspace
GSR tranny.. LS 5th gear
Originally Posted by Celerity View Post
Nothing says class like Willie Nelson on your pussy.
MY For Sale thread
eg6sir is online now   Reply With Quote
Old 02-29-2008, 02:27 PM   #37
jtornado's Avatar
Ride:  92 Civic Si
In the future I think ill go with that but in the mean time I can only get my hands on the LS which is awesome too cause I'm getting it basically for free
Old 03-04-2008, 02:01 PM   #38
Rep Power: 0 aron44 is on a distinguished road
what about the type r trany
aron44 is offline   Reply With Quote
Old 03-04-2008, 02:02 PM   #39
Blanco's Avatar
It's basically a B16 transmission with an LSD.
Old 03-04-2008, 02:11 PM   #40
so whats the best one for a LS turbo for 1/4 mile car.
Old 03-04-2008, 02:31 PM   #41
HS RA
eg6sir's Avatar
Ride:  Le Car
Gsr Lsd
MY For Sale thread
Old 03-04-2008, 03:01 PM   #42
you get the BRAKE
LS_VTEC's Avatar
Ride:  99 YZF-R6
If I had it my way... B16 1st, 2cd, 3rd, gsr 4th and LS 5th. I like the gsr's 4th gear because it is slightly longer than the b16, much shorter than the LS and is great for highway downshifting at higher speeds... This involving turbo that is.
Old 03-05-2008, 01:01 AM   #43
Rep Power: 0 AWDrifter02 is on a distinguished road
i thought i started this thread to get some help from ppl with experience??
AWDrifter02 is offline   Reply With Quote
Old 03-05-2008, 12:52 PM   #44
Blanco's Avatar
If you don't like the answers, feel free to try Honda-Tech.
Old 03-05-2008, 01:10 PM   #45
jtornado's Avatar
Ride:  92 Civic Si
See blanco your still saying it in a smart ass way.
You could have told him hey sorry about the other posts, were trying to help you out as much as possible but instead you say if you dont like the answers feel free to try honda-tech. That doesn't help bring in people. Think before you act and yes I will do the same.
Someone had to tell you blanco and unfortunately it had to be me. Block me all you want, what point are you trying to prove, that you know how to use the block button. Yes I said that in a smart ass way because you have been a smart ass to me from day 1. Anything you wanna say PM me so these threads don't get out of hand. Sorry for all the trouble but I had to say this.
Old 03-05-2008, 01:22 PM   #46
Blanco's Avatar
