ls vtec
Old 07-04-2009, 04:30 PM   #1
Rep Power: 6 93y7 is on a distinguished road
Default ls vtec
when doing an ls vtec can i run stock b18 not takin apart and use the dowel set and plug from the golden eagle kit and just put the b16 head on it?? i have read that the bottom end needs to be balanced... is this a must? and if so how come?
93y7 is offline   Reply With Quote
Old 07-12-2009, 02:39 AM   #2
Gnarphantom's Avatar
Ride:  LS Swapped CRX
Rep Power: 4 Gnarphantom is on a distinguished road
Do some research, then you would find out that the reason people talk about balancing is because you are adding reachable RPM's with the B16 head on it and the LS's were not made to rev that high. The rod bolts are junk.
Plus you will need way more than just "the dowel set and plug from the golden eagle kit and just put the b16 head on it"
Do some research before you ask the most asked questions ever, check this out -
Build a Reliable LS/VTEC
Gnarphantom is offline   Reply With Quote
Honda vtec p28 p30 p72 tuned ecu ls/vtec b20/vtec gsr RSS-Bot Auctions 0 03-19-2009 11:03 PM
Honda vtec p28 p30 p72 tuned ecu ls-vtec b20-vtec gsr RSS-Bot Auctions 0 03-19-2009 09:36 PM
Skunk2 Composite Fuel Rail B18C B16A LS VTEC B20 VTEC RSS-Bot Auctions 0 03-16-2009 11:36 AM
94 integra ls non-vtec to gsr vtec question...vtec not working. muuurph HYBRID -> EG-EK / DC 11 11-02-2008 01:57 AM
2000 ITR Integra Vtec head B18C5 B18C B16A LS/Vtec RSS-Bot Auctions 0 12-24-2007 11:23 AM
