LS-VTEC BUILD. HELP!!! opinions......
Old 10-17-2009, 02:31 PM   #1
Rep Power: 15 SPEEDFREAK0920 is an unknown quantity at this point
Send a message via AIM to SPEEDFREAK0920
Arrow LS-VTEC BUILD. HELP!!! opinions......
I was building a ls-vtec for boost but I need the car running asap so I'm thinking about going n/a.....
Here is a list of all my parts, just so you guys can get an idea of where I'm at so far:
-B18B block (decked,honed,hot tanked)
-B16 head (all stock. fresh out of the machine shop with new oem valves/springs/retainers. have reciept for all the work FRESH!)
-S80 transmission (wanted the longer gears for my initial turbo build. Will this hurt me when going n/a? Or will I be able to run this tranny for awhile and still get decent performance out of it?)
-Eagle H-beam rods
-CP 9.0:1 compression standard-bore pistons (This, besides the tranny, is the only thing i need to change out for N/A. I am either going to sell these off and buy some aftermarket high comp. pistons or if I find anyone who is willing to trade, I'll trade for high comp pistons. WHAT COMP. DO YOU GUYS SUGGEST FOR DAILY DRIVING ON 93OCT. GAS? I want to make the most power possible while still being reliable and a DD)
-all ARP BOLTS/STUDS
-all ACL RACE BEARINGS
I still need the small random stuff but for the most part I have everything ready to go. My main ?'s/concerns are:
I PLAN ON RUNNING ITR/CTR CAMS (WILL THESE MAKE GOOD POWER WITH MY SETUP OR SHOULD I SAVE AND PURCHASE SOME STAGE 2/3 CAMS?) and.....
WHAT COMPRESSION PISTONS SHOULD I GO WITH? As stated, this is going to be my DD and run on 93oct. and lastly.....
WILL MY S80 TRANNY BE FINE TO RUN WITH THIS N/A SETUP? i'm just worried that this trans will make my car feel like a dog with the long gears.....
If I had the $ I'd finish my turbo build but things have come up and I recently lost my job, so I just want this thing running! I have some turbo stuff that I'm able to sell off for some extra $ for the cams or whatnot. Thanks for everyones help and responses
d0mestics are like tampons...every pussy needs one
SPEEDFREAK0920 is offline   Reply With Quote
Old 10-17-2009, 08:18 PM   #2
Bump
Old 10-18-2009, 02:47 PM   #3
SlushboxTeggy's Avatar
Ride:  1997 Integra
Rep Power: 196 SlushboxTeggy has a reputation beyond repute
SlushboxTeggy has a reputation beyond reputeSlushboxTeggy has a reputation beyond reputeSlushboxTeggy has a reputation beyond reputeSlushboxTeggy has a reputation beyond reputeSlushboxTeggy has a reputation beyond repute
Send a message via AIM to SlushboxTeggy Send a message via MSN to SlushboxTeggy
Why not just build it N/A for the time being with the parts you have? Then when you get the cash, turbo it?
Like water on a duck's back, just let it roll off...
RIP Shaunie T. O'Reilly- 1986-2006
SlushboxTeggy is offline   Reply With Quote
Old 10-19-2009, 01:21 AM   #4
drive around with 9.0:1 compression?! I'd eat up gas like crazy. Not good for a DD hah Or will I actually be able to get away with doing this?
Old 10-19-2009, 06:32 AM   #5
Rep Power: 0 Egturbohatch is infamous around these partsEgturbohatch is infamous around these parts
just wat slush said, build it wit watever u have and dont beat on it just drive it normally( i kno it's hard to do) patience! and wen u do have the money all u need is the turbo kit and something to tune with, i suggest Hondata s300 it's good and cheap..$600....it's ok to drive wit low comp and no turbo but dont push it....patience, im in the process of building a straight Ls turbo on my hatch and now i aint got no car to drive in the winter...dat sukks!!!...
Egturbohatch is offline   Reply With Quote
Old 10-19-2009, 11:20 AM   #6
if that's the case, then I might just put it together with the low comp pistons i have.
Anyone ever done this? Will I do any harm to my bearings/rings? thnx
Old 10-19-2009, 11:22 AM   #7
as for tuning, i was going to run a chipped ecu and CHROME or EC TUNE.... suggestions/thoughts?
Old 10-19-2009, 05:28 PM   #8
F.I. Junkie
Ride:  1996 Civic, 1992 Accord
Rep Power: 101 Matts96HB has a reputation beyond repute
Matts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond repute
Send a message via MSN to Matts96HB
ECTUNE ftw if you have the cash to pay someone to tune with it. CROME if you don't. Hondata if you already have it in your car.
Drive your car all motor. Sure it's gonna be slow, but who cares. Not much good weather left anyway.
XBOX LIVE GT: teb00stcat (00's are zeroes)
-320 WHP EJ6-
Matts96HB is offline   Reply With Quote
Old 10-19-2009, 09:27 PM   #9
Ride:  1997 Integra
There are plenty of stock Honda motors that have compression between 8.8:1 and 9.5:1. Hell, a stock LS is 9.2:1.
Old 10-20-2009, 12:30 AM   #10
matts96hb: sounds good. I will try ec tune if i have the $ like you said. but for sure either that or chrome
slushboxteggy: you make a good point. thanks for pointing that out to me
so I am definately going to run my setup n/a til i can afford the turbo stuff. thanks again guys much appreciated
Old 10-20-2009, 12:59 PM   #11
F.I. Junkie
Good choice. It's easier to break an engine in when you don't have the turbo setup on there too. Ask me how I know
-320 WHP EJ6-
Old 10-20-2009, 05:16 PM   #12
how do you know that?! haha j/k
320whp is a nice #. I want to have a quick spooling setup so I'm leaning towards a gt30r or maybe something smaller like a gt28r. If I hit 400whp I'll be more than happy
Old 10-20-2009, 05:36 PM   #13
mdpsEG's Avatar
Ride:  JRSC B20/vtec DC, Nissan Xterra SE
Rep Power: 43 mdpsEG has a brilliant futuremdpsEG has a brilliant futuremdpsEG has a brilliant futuremdpsEG has a brilliant futuremdpsEG has a brilliant futuremdpsEG has a brilliant futuremdpsEG has a brilliant futuremdpsEG has a brilliant futuremdpsEG has a brilliant future
i agree, just build it with what you have. its will still run fine with 9:1, and it will be ready to go for turbo.
mdpsEG is offline   Reply With Quote
Old 10-20-2009, 11:39 PM   #14
Boosted ls/vtec ohh yeah!
boostin4fun's Avatar
Ride:  EM1 EBP boosted ls/vtec, EM1 EBP Daily Driver
Rep Power: 18 boostin4fun has a spectacular aura aboutboostin4fun has a spectacular aura about
Like matt said its easier to break in a fresh motor without a turbo setup. There is way less chance of putting the fresh motor in a lean situation when its N/A. Not to mention a fresh ls/vtec with only 9:1 compression is still a snappy little bitch! Let everything break in properly and when the funds come through boost and tune that shit.
My build threads:
http://hondaswap.com/engine-building...c-build-84953/
http://hondaswap.com/engine-building...inished-92905/
I offer ecu socketing/chipping, tuning, swaps, and builds. PM me for details and pricing.
boostin4fun is offline   Reply With Quote
Old 10-21-2009, 12:29 AM   #15
thnx for all the responses
I will make a new thread of the car and how it performs 9.1 n/a. I'll post some dyno graphs for sh*ts n giggles because it will be tuned on a dyno
Old 10-22-2009, 02:22 PM   #16
F.I. Junkie
GT3076R if you plan on seeng 400whp.
A GT28R will strain to get you there.
-320 WHP EJ6-
Old 10-22-2009, 02:26 PM   #17
I found a nice gt30r for 850..... still trying to see what else is out there
Old 10-22-2009, 02:44 PM   #18
F.I. Junkie
Thats a really good price on that turbo. I'd jump on it.
-320 WHP EJ6-
my b16a jdm enigne or b18 block with b16 vtec head aka ls/vtec build rkwoos12 Engine Building 0 08-01-2009 04:13 AM
Need some opinions on this build... Dustin_m Computers, Games, Electronics etc 43 10-17-2008 11:15 PM
Track/DD build list (Opinions/suggestions?) SolDriver Civic and del Sol - EG and EK 5 11-21-2007 03:02 PM
LSVTEC build opinions IntegralTendencies Engine Building 5 09-11-2004 06:28 PM
need opinions on d15b2->d15z6 build ssl2k Engine Building 5 08-19-2004 12:05 AM
