ls/vtec buying rebuild kit will this set up work?
Old 07-29-2007, 09:37 PM   #1
Rep Power: 5 jits1980 is on a distinguished road
Default ls/vtec buying rebuild kit will this set up work?
Hey guys im building a 92 ls/vtec. I was going to buy a rebuild kit to rebuild the engine while we did the conversion. My ? is if i buy a GSR rebuild kit it includes
Eristic Head Gasket Set, ACL Duraglide 780 Bearings Kit
NPR Chrome Pistons Rings 81mm, JDM GMB New Water Pump
Koyo Timing Belt Tensiner, New JDM Timing Belt
New JDM Oil Pump, High Quality Gasket Kit Includes:
Multi Leyer Head Gasket, Valve Cover Gasket, High Performance Viton Valve Stems,Intake Gaskt, MLS Exhaust Gasket, Cam Seals, And More!!.
Will these Parts work on the LS Block b/c i wanted to use the GSR oil pump water pump and timing belt or should i buy a ls rebuild kit and have them put in a GSR timing belt, oil pump and water pump. Please help i am new at this
thanks
jits1980 is offline   Reply With Quote
last nights chat pissedoffsol Members' Lounge 22 12-03-2003 02:56 AM
Work XZILER8 Members' Lounge 4 06-20-2003 03:06 AM
Keep Gsr Or Go Ls/vtec TegraTuner HYBRID -> EG-EK / DC 3 05-15-2003 10:13 PM
Auto Body Work JrSiRb16A Members' Lounge 6 02-16-2003 05:35 PM
