I own a 1991 Integra LS with about 120,000 miles on the odometer. I've researched the LS/VTEC conversion and decided it's a viable and relatively inexpensive alternative to swapping in an ITR engine and tranny.
I have made a list of items that are required and I am open to any suggestions on alternatives or anything I may have forgotten. The list is as follows: -B16a head -Wiring harness -ECU -Oil line kit -Apex'i V-AFC -New LS timing belt I really want to use my existing block and just freeze the rods to reinforce them. Is this safe to do or should I obtain a new block or otherwise? Like I said, I'm totally open to suggestions. The labor is not a problem; I know a couple of experienced mechanics who are going to do it for free. Thanks for any input. ![]()
"Conventional wisdom would have one believe that it is insane to resist this, the mightiest of empires... but what history really shows is that today's empire is tomorrow's ashes, that nothing lasts forever, and that to not resist is to acquiesce in your own oppression. The greatest form of sanity that anyone can exercise is to resist that force that is trying to repress, oppress and fight the human spirit." -Mumia Abu-Jamal |
Ride: 88 Honda Civic HB
from what i hear freezing the rods make it harder but it also becomes much more brittle.
1988 Honda Civic STD-more mods than I want to list Terrorists have successfully attacked our imagination. RIP Jon Eban Nie, August 31, 1991 - May 7, 2006 Y-Daniel Siu Eban, September 7, 1986 - May 7, 2006 |
GNU/Linux Evangelist
Ride: The Cheapest Road Bicycle I could get
It's not so much the strength of the rods as the rods bolts that is the concern. Get some ARP bolts, they are like $55 for the LS. Pretty cheap for a little insurance. I would also reccomend that you get a VTEC oil pump, water pump, and timing belt.LS pistons are okay, but your would be better off with some B16 pistons. The valve reliefs are too small in the LS pistons for the VTEC intake valves, so depending on the cams you run there could be interference problems.
v3sw7+9Chw6ln3pr7Ock4ma9w3TXm3l7GDF i7Ce6+8t4MNb8Oen6g6RAOa26s5MRp6 hackerkey.com |
Would this combo be a powerful and reliable engine? And would it work?
B18 block, B17 crank, civic type r pistons, civic type r rods, B16a head, civic type r cams, ARP head bolts, GSR water pump, GSR pickup, GSR oil pump, block girdle, and AEM cam gears. Then have everything balanced, head ported polished with dual valve springs, honed block and a block guard. ![]() |
#6 | |
#7 |
sounds alright but the ctr rods won't work as they are not long enough you'll need to go custom. also, if you go with gsr pump you'll need gsr timing belt. i think the best combo would be to stay with ls crank, eagle rods, ctr pistons and have balanced. as far as the p&p i wouldn't worry about that until you have the other components to go with it because gains will be minimal. good luck
| LS/Vtec turbo? | UDT | General Tech and Maintenance | 5 | 11-20-2003 10:53 AM |
| LS/VTEC? or LS/Turbo? or both? | RFHOMI2U | HYBRID -> ED-EF / DA | 11 | 10-18-2003 07:27 PM |
| ls/vtec werd | KWJaY | Engine Building | 11 | 09-10-2003 05:39 PM |
| ls/vtec integra | silverfox | HYBRID -> EG-EK / DC | 5 | 06-30-2003 11:00 AM |
| Ls/vtec Or Ls/t ? | WhItE90CRX | General Tech and Maintenance | 2 | 04-10-2003 05:03 PM |
