Does anyone know if i can put gsr crank in ls block n what i have to do to the block
the thing is i have an ls block ls crank pistons n rods and i also have gsr crank pistons and rods wanted sum advise on wat would be best set up with wat i got i waould appreciate it the advise im kinda confused |
The LS crank has a longer stroke than the GSR crank which will in turn give you a little more torque. Ive heard of an LS crank in a GSR block, in which you have to plug the oil squirters and bend them out of the way just a little, but not the otherway around.
Brutal Moderator
Ride: 97 Integra LS Coupe
I would stick with the LS crank. That's why an LS/VTEC can make more torque then a standard GS-R engine, the longer stroke...
Ride: '92 Hatch si w/B16 (wannabe EG6)
What ever you do....Don't be a foolish, lazy tuner and not micro polish the crank or think its okay to put any bearing in there you want. Smart thing is to balance it down there to the best of your abilities. Or suffer a spun bearing/blown motor before it even breaks in.
"Meow, you know how fast your were going back there?" http://hondaswap.com/hybrid-eg-ek-dc...si-b16-286581/ |
#5 |
so should i put the gsr pistons on ls rods because i was searching and read that i wouldnt be able to put gsr pistons and rods with ls crank because the gsrs total would be 87.7mm length n the lss are 89mm length if im not wrong
#6 |
Aftermarket for the set up or Shot peen LS rods.
#8 |
seņor member
Ride: 95 Teggy
p30 pistons are best, they bump your compression 20 11:1-11.5:1 perfect for 91-94 pump gas.....with a good tune of course.
Tired Of Having My Car Broken Down Will Some One please Slap Some Knowledge In My Head? Reptiles Rock! |
#9 |
shoot peen is a machining process that strengthens the rods. Not as good as reputable aftermarket rods but stronger then just plain LS rods.
| Wich one to get | brettfessler | Civic and del Sol - EG and EK | 11 | 10-18-2007 11:27 AM |
| wich to buy ???? | MiamiEgGSr | Civic and del Sol - EG and EK | 1 | 08-26-2007 03:28 PM |
| wich one is te best | MiamiEgGSr | Civic and del Sol - EG and EK | 4 | 08-19-2007 05:47 PM |
| wich one 1.5b1 or a d1.6y8 is better | 1996cool | HYBRID -> ED-EF / DA | 5 | 05-25-2006 04:20 AM |
| wich obd is a b18a | erebunicrx | HYBRID -> ED-EF / DA | 3 | 03-19-2004 09:26 PM |
