Lsvtec Or Crvtec Project
Old 06-03-2003, 06:52 PM   #1
Rep Power: 28 rsaeini is off the scale
i've been looking for a block to start my project. I still haven't decided if I'm going to go CRVtec or LSVtec so my question is what block would you guys go with for each project?
which B20 would you consider?
which B18?
what are the advantages and disadvantages of each?
"let those who judge me burn in hell until their Hondas are repossessed" - ME 1.6-1.8
rsaeini is offline   Reply With Quote
Old 06-03-2003, 07:30 PM   #2
GNU/Linux Evangelist
lsvtec's Avatar
Ride:  The Cheapest Road Bicycle I could get
Rep Power: 69 lsvtec is on a distinguished road
My vote: B18 block (whch one doesn't really matter) with an 85-86mm sleeve.
v3sw7+9Chw6ln3pr7Ock4ma9w3TXm3l7GDF i7Ce6+8t4MNb8Oen6g6RAOa26s5MRp6 hackerkey.com
lsvtec is offline   Reply With Quote
Old 06-03-2003, 08:25 PM   #3
B18 Resleeved, don't spend more on a B20 the shit is the same from the factory except the B20 has 84mm sleeves. Resleeving only costs 500 and then your set to go.
Milan
13.3@103 MT's &amp; Gutted
-Project 5 - Motor A (???)
Old 06-03-2003, 08:54 PM   #4
i got quoted $913 to sleeve it out to 84.5mm by RS Machines out here in Torrance, CA
&quot;let those who judge me burn in hell until their Hondas are repossessed&quot; - ME 1.6-1.8
Old 06-04-2003, 02:11 AM   #5
RETIRED
pissedoffsol's Avatar
Ride:  Electric Scooter
good price....
but i don't believe in anything over 84mm. the head jsut gets all wierd.... i dunno
Old 06-04-2003, 10:54 AM   #6
B, you're saying $913 is a good price? I think it's tad bit too much when Milan is saying it should only be about $500.
If it doesn't matter which block i use then i'll just get the cheapest B18 that's in the best shape. I found a few B18A shorblocks for hella cheap prices, i might jump on one of those.
I think because of the price to sleeve it out to like 84mm i'm going to pass on it, i'll just do a .25mm overbore and slap some oversized CTR pistons in there.
with the CTR pistons i'll be running a little higher compression, right? are we talking 11's or are we talking about 12's. cuz i want to be able to drive this thing around on pump gas without any problems. any suggestions. Pills, I know you're using the oversized pr3 pistons, what kind of compression are you running and how does it run on pump gas?
NOTE: the CRVtec is officially out the door, the doors are wide open for LSVtec.
Old 06-05-2003, 12:56 AM   #7
Ride:  01 is300, 05 s2000, 03 rx300
Rep Power: 57 pills_PMD is an unknown quantity at this point
Send a message via AIM to pills_PMD
according to the cspeed compression calculator i run 12.3:1 and i run fine on 93 octane pump gas. i have the head milled 20 thousandths.
the ignition map is 1 degree more advanced than a stock gsr and the ignition timing is set at 16 degrees
pills_PMD is offline   Reply With Quote
Old 06-05-2003, 06:36 AM   #8
RETIRED
hondata > compression
there's a b18b block for sale in the classfieds for 200 bucks... http://www.hondaswap.com/forums/index.php?...=ST&f=5&t=14714 towards the bottom of his post
and yeah, i consider $9xx to sleeve/bore/hottank a motor a good price. most times its around 1100-1200 plus shipping.
Old 06-05-2003, 06:45 AM   #9
Rep Power: 29 knowledge is off the scale
Don;t foget the .2L displacement between the B18 and the B20 blocks. You could still bore the B20 out to a 2.2L the B18 can be bored out to a 2.0L( safely)! If ou are on a budget go for the B18. Of you got dough running out your poors then hit up a B20! Yes B is right to get all of that work done... $900+ is a descent deal.
The C5 is strong with this one........
knowledge is offline   Reply With Quote
Old 06-05-2003, 07:48 AM   #10
Retired OG
Ride:  Integra, Tahoe
Rep Power: 43 kyleirwin has a spectacular aura aboutkyleirwin has a spectacular aura aboutkyleirwin has a spectacular aura about
Send a message via AIM to kyleirwin
Originally posted by knowledge@Jun 5 2003, 05:50 AM
You could still bore the B20 out to a 2.2L...
holy god no! the walls would seriously be paper thin... even if it is sleeved.
Kyle I. Collins, PmD.
kyleirwin is offline   Reply With Quote
Old 06-05-2003, 07:54 AM   #11
Are you sure about that? I have heard of a couple people boreing thier B20's out to 2.2L! Maybe that last beer is kicking in, but I am about 98% sure of it.
Old 06-05-2003, 10:21 AM   #12
good looking out. and he lives in LA. I just may drop him a PM.
Old 06-05-2003, 02:52 PM   #13
K2e2vin's Avatar
Ride:  88 Honda Civic HB
Rep Power: 150 K2e2vin has a reputation beyond reputeK2e2vin has a reputation beyond repute
Send a message via AIM to K2e2vin  FaceBook
you cant just simply bore it out to 2.2L, i dont think you will even have cylinder walls after that; ive calculated a bore of about 88.7mm would be needed for the b20 to hit 2.2L. the people that got 2.2L from b20 most likely used a stroker kit.
1988 Honda Civic Standard-more mods than I want to list
1992 Honda Accord LX
1996 Toyota Avalon-Spun bearing, for sale.
Terrorists have successfully attacked our imagination.
RIP
Jon Eban Nie, August 31, 1991 - May 7, 2006
Y-Daniel Siu Eban, September 7, 1986 - May 7, 2006
PROJECT : Not Our Project Smonkeyboy Members' Lounge 21 06-01-2004 05:02 AM
project lsvtec bottom end lsvtecpowa Engine Building 0 03-19-2004 09:37 PM
b22 crvtec turbo project R.E.Developement Forced Induction 5 01-20-2004 05:38 AM
CRVTEC VS. LSVTEC wngfn05 HYBRID -> EG-EK / DC 18 07-12-2003 02:25 AM
Lsvtec Project Is Complete pills_PMD Engine Building 36 05-17-2003 08:17 AM
