This is a discussion on lsvtec intake in the Engine Building forum
Well I'm looking for so advice I have a ls vtec I have put together and I have two intakes to use a 72mm ericks racing throttle body on a type r intake but isn't bored out to match. Then I have a type r ...
| | #1 |
| Well I'm looking for so advice I have a ls vtec I have put together and I have two intakes to use a 72mm ericks racing throttle body on a type r intake but isn't bored out to match. Then I have a type r intake with a 75mm edelbrock throttle body with a adapter plate welded on and bored out but the sensor is welded on the back of the intake is welded up so I don't know how it it will idle on warm up anyone's input would be great thanks |
| | #2 |
| If the motor is stock, then run a stock TB. If you had some cams and head work done the bigger TB would be beneficial. |
| | #3 |
| Ok well its not stock at all... It has been built 11.5 to 1 comp forged rods port polished head stage 2 cams... Maybe I should ask a different question. On the 75mm the sensor on the back of the Intake is welded up so will it idle wrong on warm up |
| | #4 |
| are you talking about the IACV (idle air control valve) if so, you need it! if its a drag car then plug it up, but if its your DD then you need to run it |
| | #5 |
| Use the 72mm TB with the Type R manifold and port match it yourself. A 75mm TB would suit a turbo motor better anyway. Plus the intake with the welded up holes will give you a terrible idle...if it even idles. |
Similar Threads | ||||
| Z6 intake on D15B2 (intake gasket?) | CRX-YEM | HYBRID -> ED-EF / DA | 4 | 02-19-2009 11:08 AM |
| Rip lsvtec | Mike_995 | Engine Building | 10 | 06-29-2008 11:11 PM |
| Best oem intake B18 non vtec intake manifold | D15Beater | Civic and CRX - EF | 0 | 02-27-2008 08:44 PM |
| CTR intake, SIR intake, OBX gsr intake manifold | yesSIR | Parts: For Sale/Trade/Wanted | 6 | 01-09-2008 12:02 AM |
