Is there any way I can make a CAI with like $40 at like home depot or something like that? Im bored and I need a CAI so if there is anything you guys have tried and works let me know. IDK if they sell piping like that there but the only thing i can think of is that PVC piping for water!?!
Sold my sol to the devil!!! not really just a friend who thinks hes the devil Now driving Suzi, My 05 Suzuki Aerio SX |
Ride: 06 Chevy Silverado
PCV pipe is rumored to be bad, due to some toxic gasdes it lets off when it gets warm. Just buy a cold air intake off of ebay for like 30 bucks. They are out there.
Ex 89 crx si,91 & 95 Civic owner. 06 Silverado RCSB 20's, 2/4" Belltech lowering kit, waiting for 2 more cylinders, 1.9 more liters, and 208 more hp engine swap. |
do u have a short ram? if so buy some dryer ducting ( i got 4 feet for $2) and run it down threw the hole where the airbox went, down into fender, or as i did, run it into bumper and cut a whole for the air to go in. if u want forced cold induction, run the piping from the bumper up into the engine bay, buy 2 flanges that goes from a circle into a square and place a filter between them, then connect it back up to ur IM, i heard u get 0.5 PSi per 20 mph u go. so 1.5 psi on the freeway, that aint to bad.
Sleepers Are the Only way to Go. 1990 CRX Si B18a(92) CAI/E, Gutted, ACT clutch/pressure plate/13lb flywheel, Crower 403 Cams, Titanium Valve springs & Retainers, Blockguard, Head Milled 20 thou, 9.8:1 Compression, AEM cam gears. 1/4 = 14.73 60' = 2.48 trap = 95.03mph Soon to get: Header, Slicks Future 13 second all motor LS! |
88 C1V1C 53D4N DR1V3R
Ride: 2006 Suzuki Aerio
Do a serach on google. you can buid an AEM style cold air intake for like $40-60. they even have instructions on ceramic coating it so it stays cooler.
i'm making one now and am going to try to do a DIY article and get it posted on hondaswap, but i gotta talk to B first. |
#5 |
I built one for pretty cheap except for the blitz mesh filter, the piping came out to be 20 bucks for a 2.5inch mandrel U bend from JCwhitney.
The easiest way to do this is buy a used shitty CAI from some kid online like stated above, I did that and then painted it flat black then added heat repellant foil style tape. It worked great. Milan __________________
#6 |
I bought my aem style cai for 30 bucks on ebay. Its fits great and all the piping and clamps were there. The filter isn't that bad, but I will replace it with a different one when I get my engine built.
#7 |
i would try jcwhinney flexible exhaust tubing instead of dryer ducting.
"You might own a British car if you consider rust to be a performance enhancement because it's lighter than virgin metal..." Tom from SCR |
#9 | |
My skin is singed but it heals my heart and with glowing pride I'll wear my scars. I'm honored by your hatred! She wanted love, I taste of blood. She bit my lip and drank my warmth from years before. |
#10 |
Not sure what you are driving currently (i didnt check, and i dont feel like looking now), but I had a PVC intake on my Prelude, it kicked ass! def. gain in performance. I used the OEM intake boot (from the TB to Airbox) and i crammed a 3in 45 degree piece of PVC into it, enlarged the hole for the factory snorkel to about 3.5 in, and ran a about 1 foot of 3in. PVC into the fenderwell. It worked great, and total cost was somewhere in the neighborhood of about $20 (without the APC Filter...hey, i was broke and bored, so i got creative). Hope i helped. It really did work out great for me, i would recommend it to anyone who wants to do a cheap intake mod. (i.e. you)
#11 |
i would highly recomend agianst using pvc. do you know what pvc stands for.
Poly-Vinyl-Chloro...something. they use a bunch of chlorine tomake that stuff, and whenyour CAI melts from heat ( it gets heated by the engine, and by the intake manifold... if youdon't belive me go drive your car hard for 15 min, then pop the hood and touch your intake manifold.) so when it does your going to be breathing all those wonderful chlorine vapors which do wonders for your lungs. those same vapors are going to go through your engine to, and i know that wont pass carb :P |
| how to make christmas cookies | pissedoffsol | Members' Lounge | 9 | 06-21-2006 06:10 PM |
| 1st Gen CRX FAQ's | pissedoffsol | Swap Articles | 0 | 01-12-2004 01:51 AM |
| how to make an LS to get more power | PRETTYBOI_ERIC_04 | General Tech and Maintenance | 8 | 01-08-2004 02:08 PM |
| How to make a homemake Kill switch?? | hondamidnighter | Car Audio / Security / Electronic Accessories | 11 | 12-25-2003 06:38 PM |
| Garage Sale | trbo823 | Parts: For Sale/Trade/Wanted | 1 | 03-30-2003 12:24 AM |
