This is a discussion on Measure for engine bearing in the Engine Building forum
To make sure I do the math correctly. To measure your bearing size would be, the inner diameter of the rod when tightened down, minus the outer diameter of the rod journal, all divided by two. Then I can find the bearing size from the ...
| | #1 |
| To make sure I do the math correctly. To measure your bearing size would be, the inner diameter of the rod when tightened down, minus the outer diameter of the rod journal, all divided by two. Then I can find the bearing size from the charts or goto honda and ask them? |
| | #2 |
| dont forget the oil clearance. |
| | #3 |
| Would the a engine manual have the oil clearence? If that were the case, it would be the (inner diameter of rod - (crank journal diameter + oil clearence)) / 2 ??? Or would the oil clearence be figured in after you divide by two? |
| | #4 |
| from what i know most oil clerances are 2thousands. be sure to measure on the diag to ensure the crank journals are square |
| | #5 | |
| Quote:
| | #6 |
| you should be able to find bearings in there if not you could be doing something wrong. |
| | #7 |
| The chart says it has b series bearings, those bearings will work just the same for a d series? I bought other cranks and could not find any that were in good enough shape that I would not have to have them ground down anyway, so I spent a couple extra bucks to get something better. |
Similar Threads | ||||
| Miata Pilot bearing questions | Guy | Other Vehicle Discussions | 14 | 11-09-2009 04:32 PM |
| wheel bearing | mholmes85 | General Tech and Maintenance | 6 | 05-20-2006 07:46 AM |
| Bearing sizes.. | Crix | Engine Building | 5 | 01-05-2005 09:37 AM |
| crank bearing spun!!! CRX | jpoenitsch | Engine Building | 7 | 06-01-2004 03:18 PM |
| Spun A Rod Bearing After 6000 Miles! | habitforming | Engine Building | 14 | 01-09-2003 09:49 AM |
