#26 |
you get the BRAKE
This is the finished product. If I had more time, I would have spent more time in the chemical bath but time was an issue..
![]() __________________
eg hatch (jdm b16) sold 1999 Yamaha YZF R6 (modded) http://hondaswap.com/engine-building...ow-pics-102486 sold |
#27 |
you get the BRAKE
CTR pistons came in...
![]() As well as the CTR crankshaft pulley (which will need to be balanced) ![]() __________________
#28 |
you get the BRAKE
I know Blanco. One cannot do those jobs with the crankshaft in. Thats why I removed it. =)
#29 |
you get the BRAKE
This is the damage on the rod journal from when I was removing the stock pistons/rods...as you can see, the only thing that will cause those marks are the rod bolts... When I used the rubber caps on the rod bolts when pushing the pistons/rods out, one of them came off... no biggie, minor machine work and polish will fix this and from what they told me, I should be fine with the ACL bearings I already bought for the rods...
#30 |
if you want the block and the head looking real clean and like new, go get them glass beaded with the blaster. it doesn't cost to much
blanco, you should tell him about using oem bearing instead of ACL bearing if he really cares about this build. |
#31 | |
you get the BRAKE
An unbalanced crankshaft can cause bearing failure early, but The crankshaft and crankshaft pulley will be getting balanced monday. __________________
eg hatch (jdm b16) sold 1999 Yamaha YZF R6 (modded) http://hondaswap.com/engine-building...ow-pics-102486 sold Last edited by LS_VTEC; 01-05-2008 at 12:29 AM. |
#33 |
you get the BRAKE
Look up at the pics of the pistons I posted... you tell me if I am going all motor or turbo =) The head is a 1st gen b16a head, with b16 valvetrain and itr cams. I am going to change the intake manifold/tb also. When I get to that point in the build I will post detailed pics
#34 | |
you get the BRAKE
#35 |
you get the BRAKE
This started out as a cheap build with just a modified rod and higher compression piston deal. But now I feel the need to do more than just rod bearings. I want 0 headaches, so avoiding the machine shop for heavy work just isn't going to happen. =)
#36 |
now when you say "blueprinting" doesn't this mean complete measurments of every moving surface? this doesn't need to be professionally done if you take the time to measure everything yourself?
getting it done professionally doesn't make me feel 100% sure its right because the shops around here dont really have a history with honda engines here in Mansfield, OH. now if i lived in cali, i would have no worrries. |
#38 |
you get the BRAKE
No, I do not blueprint. I go by oem clearances/tolerances. There really isnt a need to blueprint my setup being its an all oem build with all honda spec. clearances. If it were, say, je/eagle build, that would be a different story. I leave balancing/blueprinting up to the machine shop if they build the shortblock for me. But most of my builds consist of oem parts. I've done one gsr shortblock with JE/EAGLE, in which the rods had to be machined. It was a shelf-stocked rod, H-beam to be exact but for some reason the rod clearance with oem bearings was too tight so I asked the advice of a machinist, Eddie Banach. He did the machining and ever since then, he has been my #1 source for machining.
#39 | |
you get the BRAKE
Like you said before, people have their own procedures when building engines. This will probably be my last oem build (for myself). I would like to learn more about blueprinting, and pickup some more precision measuring instruments so I can move onto forged pistons/rods. I enjoy this a lot and hope to become, one day, a very respected engine builder. __________________
#41 |
you get the BRAKE
Throw that header in the garbage. I have one, its junk. That ebay replica is better, the quality of material used to fab it is not the same as the real deal Hytech but it will out perform the dc sports. I am personally going to run one of my lsvtec if I can get my hands on one next month. If not, ill shell out the cash for Rage or SMSP.
#43 |
you get the BRAKE
Tomorrow (Monday) morning, I will be heading to the machine shop with the old pistons/rods, new pistons and the crankshaft. Turn-around time for the machining I need will take about 2-3 days. Ill post pics when I get it all back machined.
#44 | |
you get the BRAKE
#45 |
you get the BRAKE
Dropped off the parts to my machinist, He will be flattening out that spot on the rod journal that I messed up, and polishing the whole crank. I purchased my piston rings and ARP rod bolts from him as well, and my ctr crank pulley will be balanced their too.
My costs: arp rod bolts $50 piston rings $50 crank polish $40 machine the rods to fit the ctr pistons, wrist pins pressed, all four $100 Balance the crankshaft pulley $FREE __________________
#46 |
you get the BRAKE
Water pump, timing belt and tensioner came in today.
#47 |
don't you have to worry about the valve clearance if you put ctr pistons into a lsvtec setup? I've got a lsvtec setup but I'd used b16 pistons but I was thinking about switching them for ctr pistons for higher compression...what do you have build in your head as far as cams and valve,retainers and valve springs?
#48 |
is lol'ing @ you
whats a good range for the piston/vlave clearance to measure if i want to turn 10k rpm or slightly higher? how should i decide to run on the close end or far end of that range? is it personal preference?
#50 |
is lol'ing @ you
lol, oh no, the most ive ever turned was about 6k with my 390. and i only did that cuz the tranny gave out at about 5k. I just ask cuz id like to be on the safe side when i take my engine to 9500 plus. thanks for the spec by the way.
| Mild LS-V Questions | Spada | Engine Building | 5 | 08-10-2006 05:29 PM |
| From B20 to lsvtec | bambam | Engine Building | 6 | 10-24-2005 10:48 PM |
| LSVTEC Dowel Pins | JayDeeEmDC4 | Engine Building | 5 | 05-23-2005 01:41 PM |
| 91 Civic Hatch LSVTEC 13 second car | david_jones001 | Vehicles: For Sale/Trade/Wanted | 15 | 03-18-2005 09:34 AM |
| Been Working Non-stop On The Lsvtec | pills_PMD | Engine Building | 8 | 05-09-2003 05:23 PM |
