Alright, so im searching around for cars, and found a SUPER clean 4dr integra LS for a decent price. Now i want a daily driver that wont fail me. But im def. a lead foot and like the power to be there when i want. Besides turbo what can i do? Would i beable to say take a gsr head, or any b series vtech head for that matter and bolt it onto the rest of the LS engine? or is there other steps i need to take?
Maybe down the road i would turbo it, but im not sure? or are there other cars i should look at that i dont really need to mess with (for example a V6 accord[even though they are a bit heavier!]) At the end i would like to have it comparable to a GSR output or Type R output as far as horsepower goes Thanks in advance to any and all help! |
F.I. Junkie
Ride: 1996 Civic, 1992 Accord
^What blanco said.
Just a tip though, look into changing the transmission out. LS has extremely long gears that really aren't good for all motor appilcations. Look into a GSR or B16 tranny. __________________
XBOX LIVE GT: teb00stcat (00's are zeroes)
-320 WHP EJ6- |
#4 | ||
I wear stretchy pants
Ride: chevy s-10
i dont know man. I 've always read that ls trannys are the best for turbo applications. More speed less shifting. My first gear was worthless in a roll race. The all motor car would wind up so fast it wasnt funny. I cant imagine having the turbo at full boost in first gear on a b16 tranny. you kinda get what i mean? I say get a DIY turbo and you should get a good 250whp. I really wouldnt go spending alot of money on an lsvtec on a fourdoor. Too much money when you can get more power for the same price from a cheap turbo kit. look up the threads that Blanco showed you and make you decision. I wouldnt do it.To me its a waste of money and time. __________________
#5 | |
F.I. Junkie
-320 WHP EJ6- |
#6 | |
Ride: chevy s-10
correct. But the torque would be there longer if the turbo spools early enough. NO? I dont know to much about them but if you reach peak boost at lets say 5k i would want it to stay there pulling harder. rather than having to shift cuz you ran out of gear really fast you have to avoid the red-line
I gues it can go both ways with different setups __________________
#7 |
91 ef/dx project
Ride: 91 ef hatchback project
with the ls long gearing would be more idel for a daily driver, cause your gonna get better fuel economy if you do alot of highway and interstate driving. To get good n/a power you could go ls/vtec, and its alot more complicated than jus trowing a vtec head on an ls block. its been covered many times on this site!!
#8 | |
Ride: chevy s-10
thats why i say no to the lsvtec. Yes its a good build if its done right.You could save alot of money and use stock parts but the parts he will need to get to 170 will not make up for the weight of the car.
You can get 170 with pr3 piston and gsr cams. Thats stock intake,decent header and tune. including stock bottom end.I would recommend studding the head and using arp rod bolts at least. Its the little thing that will make it expensive. like the pumps,belts,gaskets,dizzy,ecu,wirin g harness etc. Why not slap a turbo kit from rev hard,greddy or just scrap your own for a reall cheap price? easily get 250whp for half the price. Trust me you will ALOT of meny to hava reliable 250whp all- motor setup. what do think about doing? well how about this. Get a b16 tranny for now and see how much more pep you get. i warn you though,highway usage is out of the question. 5k at 50mph is not fun. You'll be burning oil like a mutha __________________
#10 | ||
Ride: chevy s-10
better yet get a B16 tranny and have a shop put your ls 5th gear in it. bam perfect combo. __________________
#12 | |
Duh!!! Shorter gears = better acceleration no matter what application. If you start spinning then you have a traction problem. Fix your traction problem and your car would be fast as hell. By getting a longer geared tranny you are esentially sacrificing power/acceleration for traction. Let me put this scenario out there for ya. B16 turboed with 300whp, b16 tranny, lsd and some GOOD tires that will stick to the road vs same engine 300whp, ls long geared tranny, open diff because no ls trannys came with lsd and stock tires. Even if you wanted to compare it a little differently, same car with ls and b16 tranny and GOOD tires with lsd in the b16 tranny and traction bars. Who will win this race from a dig?? Basically if you are having traction problems with your turboed car and have a b16 tranny instead of buying an ls tranny why don't you just turn down your boost. You will be just as quick. |
#13 |
thanks for all the responses!
i dont need a car that will do 170mph down the road lol.. just something thats fairly quick and will get up and go if i need it to (seeing as most people in ohio suck at driving lol) i dont know about turbo kits though, considering i havent really looking into the main compenents that would be needed to upgrade to beable to be a reliable turbo'd daily driver. Which car/motor do you think the best would be for turbo/buliding? |
#14 |
Any... B16, B17, B18c, B18B, B20, D16Z, D16Y, H22, H23.... Pick a car you like the looks of then work with it.
How much you want to spend? Actually do some research and figure out what you want to do on your own. If you have questions along the way ask them. Last edited by dtob; 12-14-2007 at 04:54 PM. |
#15 | |
F.I. Junkie
Shorter gears typically mean faster acceleration though. If you spin the tires work on traction. Im workin on a built and boosted LS. Shooting for about 300whp and I can guarantee you that I will have traction problems until I learn how to drive it correctly and get some traction parts. EDIT: ^ thats with a b16 tranny w/LSD.. __________________
-320 WHP EJ6- |
#16 | ||
Brutal Moderator
Ride: 97 Integra LS Coupe
#17 | ||
Ride: chevy s-10
i see. You guys seem to know more on this than i do so i'll take your word for it. all that for him to reject the turbo idea ![]() I say get a b16. simple and common swap with enough spunk. __________________
#19 |
Ride: 97 EX with B18B
Ok, I have an ls b18b engine in my civic but want to turbo it. What do I need to do to my engine to hold 250 with no problems? I have the money and skill to do the work myself.
#23 |
F.I. Junkie
I'm sure it would work with an obd1 car, you might just have to do some modifying. I'm not sure what all is different. It is usually better to get the right kit for your car the first time around though.
-320 WHP EJ6- |
#24 |
you get the BRAKE
manifolds are the same, so yes it will work.
as for trannys, it all depends on what you want to use the car for. you say DD. so go with the LS so you can get those high mph pulls and you WILL want the longer gears for turbo. LS is my #1 choice. My 10.20 hatch was running an LS transmission __________________
eg hatch (jdm b16) sold 1999 Yamaha YZF R6 (modded) http://hondaswap.com/engine-building...ow-pics-102486 sold |
#25 |
you get the BRAKE
as for the fitment, it will fit just fine, body styles are near the same other than bumpers/interior.
| WTB 90-93 Integra parts | onetyme_sam | Parts: For Sale/Trade/Wanted | 8 | 02-12-2008 02:02 PM |
| 2000 Acura Integra Master Power Window Switch Gray | RSS-Bot | Auctions | 0 | 11-26-2007 06:23 PM |
| 1994 - 2001 acura integra power antenna | RSS-Bot | Auctions | 0 | 11-09-2007 03:56 PM |
| the new v8 powerplant for the M3 info | pissedoffsol | Other Vehicle Discussions | 19 | 03-28-2007 05:02 PM |
| How a car amp works (pic) | cheese9988 | Car Audio / Security / Electronic Accessories | 11 | 08-29-2006 08:03 AM |
