My new pistons and rods...
View Poll Results: ?
Coooooooooool 5 100.00%
Voters: 5. You may not vote on this poll
Old 03-05-2004, 05:29 PM   #1
Admin with a big stick
Calesta's Avatar
Ride:  2003 S2000
Here are some pictures of my new pistons and rods from last week. They're at the machine shop right now with the block...
The pistons are made by CP, and are from Import Builders. The static compression in my new engine setup will be 12.77:1. The coatings are by Swain Technology. The tops are coated with their Thermal Barrier Coat, and the skirts are done with their low friction PC-9 coating.
The rods are Import Builders' "Ultralite" rods- which in reality are Probe Ultralite rods. They're about 15-20% lighter than the Eagle H beam rods.
Here come the pics:
Pistons:
Rods, Eagle vs new Probe (Eagle = H beam, Probe = I beam)
Old 03-05-2004, 05:34 PM   #2
Ride:  94 Integra GSR
Rep Power: 31 brc80 is an unknown quantity at this point
Looks good man. How long does this build plan to last? j/k
1994 Acura Integra GSR
Power:
AEM V2 Cold Air Intake
GReddy 4-2-1 Header
GReddy Evo 2 Exhaust
Suspension:
Tanabe Sustec Pro S-0C
brc80 is offline   Reply With Quote
Old 03-05-2004, 06:09 PM   #3
Ride:  '92 Civic CX
Rep Power: 39 D See 2 is an unknown quantity at this point
Send a message via AIM to D See 2
calesta
my man stays having badass allmotor builds.
Garage:
1992 CX Hatch > Current Money Pit
Grave:
R.I.P. 1995 Integra GSR
R.I.P. 1990 DX Hatch
R.I.P. 1990 CRX Si
D See 2 is offline   Reply With Quote
Old 03-05-2004, 06:34 PM   #4
Calesta's Avatar
Ride:  2003 S2000
brc80- hopefully a lot longer than the last one.
DTEC- thanks man! I'm still reaching for that 250whp target and the sweet broad power curve.
Old 03-05-2004, 07:30 PM   #5
Member of the 20 nut club
E_SolSi's Avatar
Rep Power: 541 E_SolSi has a reputation beyond repute
E_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond repute
МОΛΏΝ ΛΑΒΈ
Old 03-05-2004, 07:40 PM   #6
Ride:  '92 Civic CX
what valvetrain are you running?
Garage:
Grave:
R.I.P. 1990 CRX Si
Old 03-05-2004, 08:39 PM   #7
Calesta's Avatar
Ride:  2003 S2000
Thanks E!
DTEC- the head is all stock for now. Stage 2 for me after the bottom end is done will be all the head work. I'm planning to use Toda C cams, matching cam gears and valvetrain, custom port/polish by someone I trust- P&P with the intake manifold also. The combustion chambers in the head will also be ceramic coated, just like the pistons.
Old 03-06-2004, 12:19 PM   #8
very nice, about time some peeps went with teh Swains, they are on my list if i ever decided to build from within for sure....
good luck mang
13.3@103 MT's &amp; Gutted
-Project 5 - Motor A (???)
Old 03-08-2004, 02:50 AM   #9
Calesta's Avatar
Ride:  2003 S2000
Thanks JD! Swain does really good work... my old roommate got his turbo manifold coated by them a few years ago, and it was absolutely beautiful. It's really not expensive either. This was their best skirt coating and their next to best top coating (Gold coat is somewhat temperamental), and it only cost $38 per piston.
« LS Dizzy | ring gap »
B20B Vtec Aftermarket pistons and rods khai_tuan_nguyen Engine Building 2 06-15-2004 12:20 AM
type r pistons and ls rods typesiracing Engine Building 7 02-18-2004 11:06 PM
CTR pistons on LS rods? jake2001z001 Engine Building 15 12-01-2003 04:15 PM
