Its currently at 11:1
jdm b16a2 stock block jdm b16a1 head 1 layer oem head gasket jdm p30 pistons skunk2 stage2 cams toda 4-2-1 apexi ws2 2.5 carsound cat stock tb/manifold aem cai I wanna raise the comp up maybe .5 (only have 91 octane in cali). Should i get the head milled? new pistons? |
HS Troll...And Mod
Ride: 2001 Honda S2000
yikes...in cali i wouldnt go over 11:1 personally. Milling the head might net you a bit, but i couldnt ive you any figures.
If you PM me with tech questions, you better have a link to the thread in your PM. Anime Informant |
You should be fine as long as you get it tuned. A thinner head gasket might be the cheapest solution. Anthing over 11.5 on 91 is kinda risky.
http://www.midwesthybrid.com |
#6 |
HS Troll...And Mod
probably gonna have to bore it to do it safely
#7 |
Tune it. That will get you more gains than bumping up your compression by a few tenths.
#8 |
HS Troll...And Mod
<div class='quotetop'>QUOTE(swanny @ Sep 29 2005, 11:15 PM) Quoted post</div><div class='quotemain'>
Tune it. That will get you more gains than bumping up your compression by a few tenths. [/b][/quote] Good input. I dunno why that wasnt my first response. Its like that dude who was trying to put his cable tranny in his 99 si when he had a hydro tranny in his other car. The obvious answer didnt come immediately to mind. __________________
#9 | |
Blah blah blah....
<div class='quotetop'>QUOTE(swanny @ Sep 29 2005, 09:15 PM) Quoted post</div><div class='quotemain'>
Tune it. That will get you more gains than bumping up your compression by a few tenths. [/b][/quote] Best advice. I'd invest in some sort of stand alone system. I'm finishing my 11.5:1 ls, and wouldn't dream of driving without a good tune. A wideband, a tablet pc, turboedit, an ostrich, a socketed pm6 and a dyno will be my car's best friends in about 2 weeks. Try tuning it and running a little more ignition advance; you'll get the power you are looking for, but look out for the smog demons. __________________
