need help building a LS VTEC
Old 10-26-2003, 09:39 PM   #1
dubrideslow is off the scale
i am about to build a ls vtec motor for my 91 integra i hae read a number of things on this but they all say to use pistons from different b series motors my problem is this i plan to build the botom end of my motor (b18a1) with a crower stroker kit which will increase my displacement to 2.2 liters and give me a compesion of 12 to 1 and i want to run about a 75 to 10 shot of nitrous to this if neone can give me any suggestion to wether this would make my engine a omb waiting to happen or nething that could help it would be apprecated
dubrideslow is offline   Reply With Quote
Old 10-26-2003, 10:25 PM   #2
GNU/Linux Evangelist
lsvtec's Avatar
Ride:  The Cheapest Road Bicycle I could get
lsvtec is on a distinguished road
check out faq and come back with any specific questions.
lsvtec is offline   Reply With Quote
Old 10-26-2003, 10:53 PM   #3
Location: originally: Napa, CA now: Phoeniz, AZ (for school)
9k RPM EG6 is off the scale
Send a message via AIM to 9k RPM EG6
first things first....
LS/VTEC is potent enough...ave the money for the stroker kit, and build internals for the 100 shot. Anything over 10:1 is not really supposed to run on 91 octane. Honda is a God as far as ALL MOTOR goes and have built motors that reliably run 11.0:1 and run on pump gas...this is thanks to a lot of knock retard and ignition timing modifications.
12:1 WILL need something other than pump gas...combine that with nitrous and you're looking at retarding the crap out of your timing. Then the whole 2.2 liter deal comes in...you'll need to match the upped displacement with correct injectors based on your BSFC (somewhere around .50-.55 off the bottle). So now you either need an MSD 6AL with an ignition retard or you need to manually adjust timing to squeeze, which is no fun.
There's a lot of factors in this bro...unless you can build a motor from the ground up and know all the equations to keep this thing from detonating and pre-igniting left and right, I'd save the money from the stroker and go with a nicely forged LS/VTEC and run a ton of bottle (WET, WET, WET, not dry system). There's a lot to consider here....e-mail me if you really want to do the build and I'll do my best to help you not blow the motor up, lol...
-B
lovemybseries@aol.com
1992 "VX" (EG6) hatchback
1992 JDM B16A (P30 ECU by Mugen)
1996 CTR S4C LSD trans (4.4 final)
Skunk II/Tokico 5 way adjustables
C/F hood, Spoon Duckbill, JDM corners
much, much more...
Best Pass is: 13.72@101
9k RPM EG6 is offline   Reply With Quote
b16a obd 0 tune up parts list feet_ HYBRID -> ED-EF / DA 6 12-27-2007 07:50 PM
How to wire vtec 92b16vx General Tech Articles 3 06-17-2005 05:13 PM
Engine Swaps 101 pissedoffsol Swap Articles 0 01-11-2004 06:54 PM
Part Numbers for 89Si/B16 OBD0 Swap steelbuster Swap Articles 0 11-16-2003 06:36 PM
LS-VTEC/CR- VTEC Info pissedoffsol General Tech Articles 1 11-10-2002 03:19 AM
