I have a 95 civic sedan and i just ordered a test pipe. I've heard many things about a test pipe good and bad. First, I wasnt sure if i was suppose to get the test pipe with the bung for the 02 sensor or w/o. Which one should of i've got. Second, would a test pipe make my check engine light go one. If so, how would i stop it from going on. Third, is it true that your car stinks if u put a test pipe on? If anyone can help that would be great.
Ride: 01 is300, 05 s2000, 03 rx300
a pipe in the place of the cat.
it will smell a little bit. it will make it sound raspy.. do you need one with a bung for the o2? do you have 2 o2 sensors? or is yours in the exhaust manifold? mine didn't throw a CEL |
| Test Pipe or Cat. Converter is worth it for my H22 | NyQuiL_AcCoRD | General Tech and Maintenance | 7 | 08-16-2004 11:11 PM |
| Drag kit install manual | pissedoffsol | Forced Induction | 0 | 07-18-2004 12:37 AM |
| High flow cat or test pipe? | swapdohc | HYBRID -> EG-EK / DC | 3 | 01-02-2004 01:38 PM |
| resetting ecu after test pipe and o2 sim. | aphex301 | General Tech and Maintenance | 2 | 10-05-2003 10:45 PM |
| engine light on after test pipe put on | XZILER8 | ECU's, Electronics, and Tuning | 4 | 01-01-2003 11:21 AM |
