Need some advise..
Old 07-23-2004, 08:22 PM   #1
Rep Power: 12 Crix is off the scale
Should i resleve this motor. My setup so far is endyns 12.5 pistons, using the egale rods. Iam also going to be using the b16 head with the itr vavletrain and thats it pretty much.
Will a blockgaurd be fine for this setup or will slevving the motor need to be done. THe b18b block iam using for all this has only 40k miles on it. The cylinder walls are in pretty good shape. I would really like to get this build done soon. And money isnt really all there to resleve the block. But should i go ahead and invest into this or will i be fine with just using a block guard?
Also I was told i need have my head ported? Iam not sure what that is yet? <_< Iam sorta new to builing or putting toghter motors. THis is only my second one but first bseries build. I had a sohc na setup. D16Z6 with oversized dx pistons.
---------My new toy--------------------------
-D16Y8w/100shot/DX pistons.
12.06@109mph.
--------Coming Soon-------------------------
-B18B1w/.25 PR3's/PR3 Head?Portflow springs&amp;retainers/Balanced&amp;Blueprinted/ITR
intake cam/b16 exhaust cam/spoon sports flywheel/CM stage 3/GSR Hydro/
GE main girdle set/ITR oil&amp;water pump/2.25&quot;piping w/blk. es oval/
Mid 12's hopfully. . . coming Spring 2005
&quot;All mtr the exspensive way to go slow&quot;
I drive a 92 NSX-Honda Technician Bronze level and own my own home.....Hate me. (haters)
Crix is offline   Reply With Quote
Old 07-23-2004, 09:54 PM   #2
B16
B16's Avatar
you dont need to sleeve nor blockguard, if the sleeves are in good condition just rehone.. why do you want to use a blockguard? it will cause more damage than good.
2004 BMW 325i
2000 Mercedes Benz ML 430
Old 07-23-2004, 10:07 PM   #3
Can you tell me why it would do more harm then good? Just asking?
12.06@109mph.
Old 07-23-2004, 10:09 PM   #4
I thought maybe since that the motor will probably see 9500rpms at the most. I had a lsvtec before that someone built and was always told just add one? Maybe to strethen up the vibration on the cynlinder walls at high rpms? I really dont know the whole reason why?
12.06@109mph.
Old 07-23-2004, 10:10 PM   #5
Slammed89Integra's Avatar
Ride:  2007 Scion TC, 2005 Suzuki GSX-R 600
Rep Power: 155 Slammed89Integra has a reputation beyond repute
Slammed89Integra has a reputation beyond reputeSlammed89Integra has a reputation beyond reputeSlammed89Integra has a reputation beyond reputeSlammed89Integra has a reputation beyond reputeSlammed89Integra has a reputation beyond reputeSlammed89Integra has a reputation beyond reputeSlammed89Integra has a reputation beyond reputeSlammed89Integra has a reputation beyond repute
Send a message via AIM to Slammed89Integra myspace
From what I understand, it goes into the existing water jackets, and this comes to my mind that it would make it more difficult for water to pass through, making it more prone to over heat.
When this is all over I think we should get an apartment together.
Slammed89Integra is offline   Reply With Quote
Old 07-23-2004, 10:16 PM   #6
what if i made for better cooling? to prevent the overheating?
What would make me feel better is last time i had a lsvtec i used oem internals .25 os itr's in a b18a1 using also a b16 head. Iam i looking at anymore of a problem with the durabilty of my slevves? Using the forged internals.
12.06@109mph.
Old 07-24-2004, 12:30 AM   #7
B16
B16's Avatar
there isn't a durability issue with your sleeves at all if you're staying all motor. when boosting is when you need to worry about sleeves, then you resleeve. or if you were to go beyond an 81.5mm piston, then you would need to resleeve. you do not fit any of these categories so you dont' even need to worry about it. like they said, it interferes with cooling, i've heard of them slipping in the jackets, becoming uneven, block needs to be rehoned after it is installed.. i find it to be a waste of money, especially in an N/A car. spend your money where it will make a difference
2004 BMW 325i
Old 07-24-2004, 01:09 AM   #8
Rep Power: 15 StyleTEG is off the scale
look into block posting, there are more details in the blockguard post 4-5 threads down.
<a href=\'http://www.limitedslipmotorsports.com\' target=\'_blank\'>http://www.limitedslipmotorsports.com</a>
StyleTEG is offline   Reply With Quote
Old 07-26-2004, 10:20 PM   #9
Rep Power: 11 Tbone is off the scale
Block guards shift the upper sleeve when you tap them in, so unless you bore the block with it in, you will do more harm than good.
If you sleeve yor block you need to ditch those pistons for some 84-85 mm ones. Why pay to sleeve then keep it a 1.8? A simple bore to 85 and new pistons and you have a 2ltr.
11sec street car club...ALLmotor
11.78@114.9
Tbone is offline   Reply With Quote
