| | LinkBack | Thread Tools |
| | #1 |
| thistownsucks... | I can get a rippin deal on a 99 CTR LSD. 1. I know the B series tranny's are interchangable as far as bolting up to b blocks, but wat about internally(sp)? What will this LSD fit? I have a Y1 cable right now, will it fit? or will the LSD only fit a hydraulic tranny. If so which one. Thanks matt |
| | #2 |
| Senior Member | not 100% sure, but i believe there is a difference between the cable and hydraulic tranny's... i don't think it will work, but... you might buy it, then use it for leverage in getting a cable one... like, get a buddy with a hydro trans to buy one for a cable trans, and swap him |
| | #6 |
| Admin with a big stick Join Date: Sep 2002 Location: Dallas / Fort Worth, TX Age: 32
iTrader: 0 / 0% Ride: 2003 S2000
Rep Power: 392 | There are 2 or 3 different bolt patterns for the final drive ring gear, and your LSD must match the stock diff if you want it to just bolt in. I don't know what all the different configurations are- it's been a while since I've peeked inside a B series transmission... but you'll have to check on that first. If it matches yours, you should be fine. Be prepared to re-shim your differential assembly though. |
| | #7 |
| RETIRED | cable diffs won't go on hydro diffs and more so ls/b16 hydro diffs won't go on gsr/itr/ctr hydro diffs the y1 sir lsd, or a quaiffe/other aftermarket are your options. |
