This is a discussion on Off centered piston...WTF?! in the Engine Building forum
i don't understand how it can be off center??? is it on backwards?? or is the rod on the crank backwards?...
| | #1 |
| i don't understand how it can be off center??? is it on backwards?? or is the rod on the crank backwards? |
| | #2 |
| sounds like a fucked up piston to me... damn, that sucks man if you are in that much of a rush you could probably dremel the piston, but thats something i would do so you might want to rethink it... i don't normally advise people to do shit i would do... |
| | #3 |
| That's....weird... Get some pictures of it.... [img]style_emoticons/<#EMO_DIR#>/shrug.gif[/img] |
| | #4 |
| wow, something is seriously wrong there... |
| | #5 |
| the only way that could happen, would be a bent rod.... and i sent the cam with some battery life left-- surely enough to snap 2 pics |
| | #6 |
| THATS A FREAKIN BENT ROD! ITS OBVIOUS, YOU CAN SEE IT? AND WHO PUT IT TOGETHER? Their freaking retarted! |
| | #7 | |
| Quote:
X 10.Seriously, what builder would put that together and deliver it to a customer?? You need to fire that piece of shit. Get a refund or something. | |
| | #8 |
| does that rod look untrue to anyone else besides me? those are stock pistons? i thought maybe they were aftermarket knock offs that could have an error in their making... |
| | #9 |
| The rod looks bent to me. |
| | #10 |
| another fine cali engine builder [img]style_emoticons/<#EMO_DIR#>/happy.gif[/img] sorry, i'll keep my mouth shut... |
| | #11 |
| When I said 'bent' rod, I meant twisted... ![]() and from that image, I'm sticking with the problem being in the rod. Swap the piston over to another rod, and that rod over to another piston, and install them in the block. If the other piston is off-center, it's the rod. If the same piston is still off center, it's the piston. |
| | #12 |
| ...since they did such a good job in the first place |
| | #13 |
| 60 miles > |
| | #14 |
| i'd bring it back to the orig shop. demnad that they fix it for free. if they don't bad mouth them all over the domestic board. |
| | #15 |
| he should have seen that, called you, and said hey- something is up. |
| | #16 | |
| Quote:
![]() my vote is gonna go to the piston being not right what rods are they? stockers? | |
| | #17 |
| if the rods havent changed its gotta be the piston then. |
| | #18 | |
| Quote:
I don't agree.... If the piston were bent/warped then how would it go into a Perfectly Cylinder hole and not be a tight squeeze especially with the rings. If they are what the appear to be as stock cast pistons then im pretty sure they would crack or break before they would alter by bending or warping. Just my .02 | |
| | #19 |
| i dont think those are stock pistons. |
| | #20 | |
| Quote:
That helps sum it up... | |
| | #21 | |
| Quote:
are nippons junk? | |
| | #22 |
| Guit-Guit? |
| | #23 |
| sorry to see that. i know others have said this but it looks like maybe the rod was drilled at an angle to get the piston pin through? hope you get this fixed and i would like to hear how this turns out since i was interested in nippons. |
| | #24 | |
| Quote:
so thats a nope that you did not get it figured out? or a nope it was not the piston, the machine shop fucked it up? | |
| | #25 |
| so how the hell did it happen? did the apprentice bend the rod? or was the rod junk? |
