i recently got my car backed from the shop and they said i need to replace my oil pump. its a 92 LS and so far ive heard both the water pump and oil pump sucks ass on the LS motor. so i was wondering, should i replace it with a different Bseries pump? like a GSR pump or something.. and if i did that would i need a new timing belt? or should i just replace the part with the identical pump? or should i get an aftermarket pump? and if i did that, any companies recommended? thanks a lot in advance.. btw, which would cost most and less?
GNU/Linux Evangelist
Ride: The Cheapest Road Bicycle I could get
A VTEC oil pump will work and because the oil pump is timed off the crank not the belt you do not need a different timing belt. The LS water pump is fine if you aren't spinning past 7200 RPM.
v3sw7+9Chw6ln3pr7Ock4ma9w3TXm3l7GDF i7Ce6+8t4MNb8Oen6g6RAOa26s5MRp6 hackerkey.com |
| fuel pump | mozzandherb | General Tech and Maintenance | 5 | 06-26-2005 04:30 PM |
| Replacing Fuel Pump | sol2nr | Engine Building | 1 | 06-01-2003 10:49 PM |
| Water Pump | jeppreyboy | General Tech and Maintenance | 4 | 05-23-2003 11:06 PM |
| Fuel Pump? | drewdrew | HYBRID -> EG-EK / DC | 14 | 02-20-2003 11:02 PM |
