Ok, I need a D motor education.
Old 01-18-2006, 07:55 AM   #1
Rep Power: 0 TreeFrog169 is off the scale
I currently have a D16Y7 with just a touch over 200,000 on the clock. I am thinking of a rebuild, but here is the questions.
What D motor has VTEC and would be an easy swap or good head swap candidate? I was thinking of a head swap to get the VTEC but is it worth the wiring time and swapping a comp? What does the VTEC gain me?
Also bottom end. Is there any differences between my motor and any other D motors? If so what is it and which is better?
D16Y7 vs other D motors, which can be built better as far as reliability and reliable power and still be somewhat economical?
This is a DD and I am just looking for a mild rebuild with some more power. The D motor is what I want because they bolt up to the trans and stuff I have. I am leaning towards just rebuilding the motor I got just for the fact that I have it and I don't want to have to find a comp, head and wiring, and do any rewiring. But if it is justifiable gains to swap heads or motors than I will consider it.
Also what are some mods I can do to my current motor if I rebuild it for good power gains but not hurt its reliabilty? What is a good source for rebuild parts?
Thanks
TreeFrog169 is offline   Reply With Quote
Old 01-18-2006, 08:30 AM   #2
cheese9988's Avatar
Ride:  2007 Chevrolet Cobalt SS Supercharged
Rep Power: 31 cheese9988 will become famous soon enough
You can put the d16z6 or d16y8 head on there for vtec, that on a new motor will give you ~130hp. There are pistons/ring/rod packages you can buy for under $1000 to rebuild it. Rollerwave pistons, eagle rods etc. If it were me with just a dd and no turbo, I would just either put new pistons of the same make in it, or get some pm7 pistons out of a dohc zc to bump up the compression, those pistons you can find used much cheaper and probably just have to find new rings for.
Is it good when my dipstick is rusty on my jeep?
Linux Mint 6.0
"The only man who makes no mistakes is the man who never does anything. Do not be afraid to make mistakes providing you do not make the same one twice."
Theodore Roosevelt
http://homemodders.com/t188/
cheese9988 is offline   Reply With Quote
Old 01-18-2006, 11:16 AM   #3
trappd-in-859's Avatar
Rep Power: 15 trappd-in-859 is an unknown quantity at this point
If you want some OK gains with the engine you have, I would go: I/H/E along with a ZEX cam and gear.
That setup should get you about an extra 10whp if tuned right.
trappd-in-859 is offline   Reply With Quote
Old 01-18-2006, 11:47 AM   #4
HS Troll...And Mod
reikoshea's Avatar
Ride:  2001 Honda S2000
Rep Power: 179 reikoshea has a reputation beyond repute
myspace
200k on the engine...find a z6 or y8 and just do a full swap...those engines are everywhere...it shouldnt be too hard to find. If you want you can add a little home made turbo setup to it and then you have yourself a 13(ish) second civic [img]style_emoticons/<#EMO_DIR#>/smile.gif[/img]
Anime Informant
reikoshea is online now   Reply With Quote
Old 01-18-2006, 12:35 PM   #5
learning in progress
formby's Avatar
Rep Power: 93 formby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud of
I'm with reik...get the whole swap and use the pm7 pistons.........then street tune .....with that CR you could even use N2o once in a while.....
but i think a D is a better platform to FI just because of its low HP output....but a high CR D is a nice daily
http://pandora.com/
Old 01-18-2006, 01:10 PM   #6
Rep Power: 11 somethingclever is off the scale
if you decide to go with a swap- i have a d16z6 out of a 95 ex that had 50k on it when i wreck'd it.
somethingclever is offline   Reply With Quote
Old 01-19-2006, 01:35 AM   #7
Admin with a big stick
Calesta's Avatar
Ride:  2003 S2000
The previous post is right on the money.
Swap in a lightly used D16Y8. Wiring for VTEC is easy. If you have the desire to take the power up a bit, drop in a set of PM7/P29 pistons- but don't run the thicker head gasket to drop your compression. I know that I wouldn't- but tuning in the high 12s (compression) is a cakewalk for me on 93 octane. If you don't want to screw with tuning, just swap in a totally stock Y8 and be happy. It's still a big improvement over your tired Y7.
Old 01-20-2006, 02:40 AM   #8
Rep Power: 0 b18_speed is off the scale
yeah i would have to agree, just save your money and get a different car which has more power goals that are easdier to obtain or do a big engine swap...
b18_speed is offline   Reply With Quote
Old 01-20-2006, 08:10 AM   #9
Ok, I found a Y8 that needs a rebuild. Will I need the Computer from it for the VTEC? Also what is factory compression ratio on this motor? What wiring is needed for this swap? Thanks.
Old 01-20-2006, 09:44 AM   #10
HS Troll...And Mod
reikoshea's Avatar
myspace
yes, you will need the computer from the 96-00 Civic EX (P2P). The Factory compression is 9.6:1. You need to wire for VTEC, that should be about it. Its gonna be 3 wires (if you count a ground as one of the wires).
Anime Informant
Old 07-23-2006, 06:31 AM   #11
Rep Power: 14 divisii is off the scale
Blanco nailed it.
Y7 & Y8 have identical bottom ends. What does VTEC gain you? 20 horsepower in stock form, that's nearly a 20% gain.
From what I've read the weakness comes from the need to enlarge and smooth oil supply through the block.
1999 Civic DX--
AEM CAI, Magnecor plug wires, 195-50/15x7 alloys
future? B or K swap
divisii is offline   Reply With Quote
Old 07-23-2006, 12:50 PM   #12
Calesta's Avatar
Ride:  2003 S2000
Eh? You just pull the oil squirter thingy between cylinders 2 and 3. There's no englarging involved. This is a 6 month dead thread anyway. Check your dates next time!
