| | LinkBack | Thread Tools |
| | #1 |
| Senior Member | Poor Mans Type R + Boost (B16 head, gsr shortblock w/LS crank) **Bold & Italic items are my concerns** Block: B18C1 Block, LS Crank, Wiseco Pistons, Eagle H-beam Rods, ITR oil/water pump, all OEM honda gaskets/bearings/belts, ARP head studs, ARP rod bolts... Head: B16A head (gen1), GSR Cams, Skunk2 IM, Hondata IM gasket... -Since I plan on running a Full-Race Kit, I will be using their manifold. What trim (B16Head, B18C1block) for the turbo. I want 9psi daily. -Should I use aftermarket or OE pistons. If I went with OE, should I just use the GSR Pistons/Rods? If I use aftermarket, what CR should I have? Lower than 9:1 or 9.5:1. -Im thinking of using an LS crank (for a tad more torque and it will be balanced/blue printed) in the C1 block, I would then need what size rods? Since hte LS has longer stroke than the GSR. I know, I know this is a VTEC build, but help me out.
__________________ 90 Integra Sedan B20V 225 / 153 I DO NOT answer tech questions via PM. Use the forums!!! |
| | #2 |
| FüK-VTEC | No, you cannot use B16 headstuds. Get the manifold/downpipe for a GSR. If you're planning on boosting and keeping OEM pistons, I'd go with the GSR's. As far as rods, if you keep stock pistons you have to keep stock rods. GSR rods with ARP bolts should be fine. Really, in my opinion, you don't even need ARP bolts, because you aren't going to be revving any higher than the GSR redline, and aren't going to be boosting anything incredible, and GSR rod bolts should be just fine. I woulnd't go any lower than that. Shit, if I were doing it myself, I'd go 10:1. Boost = more power. Higher compression = more power. Boost + higher compression = more power. Period. Sure, people will say 'but it's going to detonate if you have higher compression with boost' or some shit like that. My response to them: TUNE THAT SHIT! |
| | #4 | |
| Senior Member | Quote:
higher comp = more power - less room for error - of course we all know this were all honda swapers ! | |
| | #5 | |
What about headgasket? GSR or B16? As far as gaskets, I know I need the GSR bottom end kit and the B16 top end kit. The headgasket is my only worry. I do plan on using GSR pistons/rods. I know if I kept OEM pistons the only option for rods, is OEM as well. This I knew. I will more then likely use ARP bolts, just for added insurance. Im going to stay away from Higer CR + boost. Especially 9psi. And yes, I know its all in the tune, which MikeBergy and I will use TurboEdit.
__________________ 90 Integra Sedan B20V 225 / 153 I DO NOT answer tech questions via PM. Use the forums!!! | |
| | #10 | |
Yea, aftermarket. But the length of the rods. <!--QuoteBegin-erebunicrx@Aug 24 2005, 04:33 PM i would go with a sc61 turbo. a local kid was making 320 on 10 psi stock gsr. but you may want a better powerband. post what kinda power you want to make. [/quote] I want maybe 300 daily driveable, dependable. | |
| | #11 |
| my name is Dale | ok, if you only want 300 first thing i would not do is buy a full race kit. there too expensive to only make 300hp. reliableity mostly has to do with tunning. so save the money from the kit, peiece a kit together and spend the rest on a good tunner local to you. |
| | #13 | |
| | #14 | |
[/b][/quote] Did you quote the wrong person? So back on topic. If I used an LS crank, what size would the rods need to be? I want to go with 9:1 CR, I am using Wiseco Pistons from IB Spec. What headgasket do I use. The B16 or the GSR, would it matter? | |
| | #16 |
| Retired OG Join Date: Oct 2002 Location: Vegas Age: 23
iTrader: 0 / 0% Ride: Integra, Tahoe
Rep Power: 44 | if you use an ls crank, you will need ls sized rods (stock ls, or aftermarket ls). ls spec. pistons will also work fine, no need for a custom piston. i'm nearly positive that the gsr and b16 headgaskets are the same. although, if you were planning on goin' oem honda from the dealer, then i would buy one for a b16 seeing that honda parts are generally less expensive than their acura counterparts. if you're shooting for 400 and no more, the full-race stage 1 kit with the t3/t04e turbo will support that fine. that turbo will also put your right abound your power goal of 300whp @ ~9psi. call todd up at full-race to discuss what trim and a/r will suit your application the best.
__________________ Kyle I. Collins, PmD. |
| | #17 | |
so, i can use LS rods (oe or aftermarket), and basically a piston designed for an LS (oe or aftermarket)? Very nice, very nice. Ill get the B16 gasket kit, it should save a little scratch, eh? | |
| | #19 | |
| | #20 | |
Rep Power: 44 | Quote:
| | #21 | |
[/b][/quote] I actually have them bookmarked. Ill do that tomorrow. got some names of HT members so I can PM em? I talked to Jeff, Im getting H beams and 9:1 IB Specs Wiseco SuperDupers!!! Uhm, but I dont know. Im trying to figure something else out. Where to get the uhm, yea the shortblock.
| | #22 |
Rep Power: 44 | http://www.honda-tech.com/zerothread?id=1277864&page=1 that's a link to the guy's thread that sells the gasket kits. http://estores.merchantpartners.com/pn280/...products_id=147 there's the link for the genuine honda lower end gasket kit from heel toe auto. http://estores.merchantpartners.com/pn280/...products_id=169 that's a link to the top end kit. says it's for a itr/b16, but i believe everything but the IM gasket will fit on a gsr head. if your budget allows, i'd spring for the genuine honda stuff, at least for the headgasket... even more so if you're going to be boosting.
| | #23 |
| Senior Member | I have a friend that works at the honda dealer back home, he's checking on prices for me. so we'll see how the OE rebuild kits goes. the least I will do is get OEM cam seals, IM and EX manifold gaskets along with the headgasket. |
| | #24 |
| Senior Member | Got one quick question. Putting the LS crank into the GSR, would this make it a 1.833L engine? Bore = 81 and Stroke = 89. Also, I looked for the displacement computer, found one. the Formula is pi/4 * bore^2blah blah what does the ^ mean? im not math genious, but ive never seen the ^ before. |
| | #25 |
Rep Power: 44 | ^ means, "to the power of". or in this case, since it is ^2, also means "squared". 3^2 = 3˛ = 3ˇ3 = 9 and yes, the ls crank will give you slightly more displacement with it's 89mm stroke rather than the gsr/itr's 87.2mm. the formula for figuring the displacement of the engine is very simple. it's the same as figuring the volume of a shape just like you did in middle school. base x height will get you the displacement of a cylinder. being that the base (cylinder area) is a circle, it makes it just a bit more complicated. the forumla is below. pi ˇ r˛ ˇ h pi = 3.1415926535... r = radius = cylinder bore divided by (/) 2. h = height = stroke. ˛ = ^2 = to the power of two = squared. plug in the numbers. 3.1415926535 ˇ 40.5˛ ˇ 89 according to math's "order of operations", you take care of the power equation first. then the rest of the multiplication. 3.1415926535 ˇ 1640.25 ˇ 89 = 458616.7641400375 that's the volume of one cylinder, multiply that by the number of cylinders (4) and you get the volume (displacement) of the engine in cubic millimeters. 458616.7641400375 ˇ 4 = 1834467.0565656015 divide it by 1000 to convert it from cubic ml's to cubic centimeters (cc's). 1834467.0565656015 / 1000 = 1834.4670565656015 and that is your 1.834L LS engine. i'll spare you the math, but the gsr/itr's displacement is 1797cc's which gives the ls stroked engine a ~37cc displacement advantage.
