um, your compression would not be affected, but you might wanna get new valvesprings and retainers because the ctr's make power above that of the b16 cams. you would not want to put in itr pistons, as they would either cause the same c/r if not reduce your c/r because they are meant for the itr stroke which is longer than that of the b16...your best bet would be getting ctr pistons.
the OG
Ride: 97 bmw m328, 08 yamaha r6s, 94 suzuki dr350, 73 honda cb350 cafe racer
Rep Power: 26 ![]() ![]() |
usdm b16 c/r = 10.205320397414986
usdm b16 with itr pistons = 10.194654591216547 usdm b16 with ctr pistons = 10.801068956759683 this can all be found on this site which i found in the HS FAQ forum when building my motor http://www.c-speedracing.com/howto/compcal...lc/compcalc.php *edit . . . i'm running 11.1 to 1 compression and use 93 or 94 octane at all times |
#6 | |
the OG
as far as i know all b18 or b16 pistons can be used on b18 or b16 rods i have stock jdm b16 pistons pressed onto stock usdm ls rods in my ls motor |
#8 |
the OG
i said "as far as i know" i guess i know a little farther now
either way my LS is puttin down more torque than a JDM ITR :P |
#9 | |
there is no way CTR pistons in a B16a block gives it only 10.8:1 CR, that is the CR of CTR pistons in the B16B!! and the B16B have the same deck height as the gsr/itr blocks, that compression calculator thinks the B16a/b blocks are the same... no way jose. CTR pistons in a B16a wil give you around 11.6:1 CR |
#10 |
When I bought my LS I bought it to VTec it. Now It does so good I am going all motor LS!
9.10 ET 1/8 mile 60ft-2.00 76.99 MPH 95 DX coupe w/ must of the interior (no seats) and MT ET slicks I/H/E and regrinded cams and that is all. |
#16 | |
you should be ok on 91 octane, get it tuned. |
#17 | |
you should be ok on 91 octane, get it tuned. [/b][/quote] Mike, you shoot down reason #2 and don't say ANYTHING about reason #1????????? How bout 93 octane? Or 100? Or 110? It's called race gas guy. Thanx for the worthless post though. |
#18 | |||
haha, guess point 2 was the only one that caught my attention :P |
| TONS of parts for sale B16, GSR, Type R | Envy_Motorsports | Parts: For Sale/Trade/Wanted | 28 | 02-08-2010 09:43 AM |
| b16 pistons - PR3 | Anthrax-VX | Parts: For Sale/Trade/Wanted | 1 | 05-11-2004 05:21 PM |
| ls block w/ b16 pistons, FI? | javenger | Engine Building | 11 | 04-29-2004 07:49 AM |
| itr pistons in jdm b16 | microfreak22 | Engine Building | 4 | 01-29-2004 10:23 AM |
| LS-VTEC/CR- VTEC Info | pissedoffsol | General Tech Articles | 1 | 11-10-2002 03:19 AM |
