Question about Vtec and tuning
Old 03-31-2009, 05:55 PM   #1
Boosted Rex
TurboRex90's Avatar
Ride:  '90 CRX SI
Rep Power: 21 TurboRex90 is a splendid one to beholdTurboRex90 is a splendid one to beholdTurboRex90 is a splendid one to beholdTurboRex90 is a splendid one to beholdTurboRex90 is a splendid one to behold
Send a message via AIM to TurboRex90 Send a message via MSN to TurboRex90 myspace  FaceBook
Default Question about Vtec and tuning
Ok so i had my car dyno'd a few weeks back. I have a d16z6, built and boosted, but no head work. On the dyno i noticed during the tune there was no significant curve from vtec, i made about 235 whp but we couldnt crank the boost any higher then 19psi because i was gettin valve float at about 6500rpm, as my redline is 7200 and so my torque starts to drop off. I recently redid my wire harness and found my vtec ground was severed. If my vtec was to work during a retune would that affect my valve float problem and potential fix it? i mean i know getting new valve springs and retainers would help but i wanted to know if that would do some justice to the problem.
TurboRex90 is offline   Reply With Quote
Old 04-04-2009, 06:09 PM   #2
Boosted Rex
TurboRex90's Avatar
Ride:  '90 CRX SI
c'mon, no one with the knowledge could give me the slightest of answer?
Tags
boost, honda, tune, vtec
OBD2 Turbo Tuning Question. Lee7pcNOOb ECU's, Electronics, and Tuning 4 03-31-2008 04:49 AM
OBD 1 Tuning and Code Question geoffrey ECU's, Electronics, and Tuning 0 02-05-2006 02:33 PM
Tuning question for my build Blanco ECU's, Electronics, and Tuning 9 12-15-2005 05:26 PM
JRSCed B18c1 and hondata tuning question kingmarc63 Forced Induction 4 12-29-2004 12:43 PM
nitrous setup and tuning question get_nick General Tech and Maintenance 2 02-12-2004 01:12 AM
