re-doing the f*ck#r
Old 07-14-2008, 11:19 PM   #1
Ride:  2000 si gt40/b18c
Rep Power: 8 honda801 will become famous soon enoughhonda801 will become famous soon enough
Default re-doing the f*ck#r
Last year i bought a gsr motor swap. put it in in about 1 day(you know how excited you get) well on startup i spun a bearings and threw a rod through the side of the block. Let that be a lesson to you, about buying someone elses sh*t. I though i would post me building a new settup on here not only for me to learn but for noobs to do the same.so please E1 feel free to give there 2 cents, but please people lets not get off the subject. Now im not sure if i wired everything right, is this something that could of caused the problem? i have a ex 00 wich originally has the vtec already wired. so i used the stock harness with a p72 and by the way this is what it looks like for a rod through the block in case you've never seen one.
honda801 is offline   Reply With Quote
Old 07-14-2008, 11:24 PM   #2
the new block is b18b definately going lsv
darton M.I.D sleeves bored to 84mm
je 84 mm 9-1 pistons
crank worked to the n*ts
eagle h-beams thats just the short stuff
Old 07-14-2008, 11:26 PM   #3
does any body know much about the girdle on the gsr. ive got all these gsr parts from the old one will it fit the ls block? are the crank journals the same size?
Old 07-15-2008, 02:27 AM   #4
Admin with a big stick
Calesta's Avatar
Ride:  2003 S2000
Rep Power: 284 Calesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud of
Journals are the same, but you have to swap out the main caps to fit the GSR girdle.... plus take care of all the machining required to do that too.
Punctuate and capitalize please.
Old 07-15-2008, 08:40 AM   #5
I have all of the mains from my gsr block. What machining is required, the look the same to me exept the longer bolts.
Old 07-15-2008, 08:50 AM   #6
And I think i figured out what the wiring problem is, tell me what you think they sent me a p72 for an 99 gsr, I have a 00 ex doesnt that mean that i need a p2t> from a si.
Old 07-15-2008, 12:44 PM   #7
learning in progress
formby's Avatar
Rep Power: 92 formby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud of
TunerToys Golden Eagle B16-B18-B20 Main Girdle Kit OE Hardware
that is all
http://pandora.com/
Old 07-15-2008, 03:13 PM   #8
Yeah but if I already have everything then why would I buy it. I just was wondering what machining needs to be done it all looks like it bolts up to me.
Old 07-15-2008, 03:16 PM   #9
The dowels line up!!!
Old 07-15-2008, 03:54 PM   #10
Old 07-15-2008, 04:21 PM   #11
Old 07-15-2008, 04:28 PM   #12
I think it will work, any objections? I think that website is just a waste of $300.00.
Old 07-15-2008, 10:11 PM   #13
Rep Power: 10 BrokenRex has a spectacular aura aboutBrokenRex has a spectacular aura aboutBrokenRex has a spectacular aura about
the machining is for ls blocks. you stole the mains off of a GSR, so you dont need to machine the dowels in there. before you go assuming it's all going to work fine, i'd have the mains all align honed to make sure there's no lips protruding into the bearing zone. quick way to spin a bearing (swapping mains off of another motor often has ones not perfectly center.) before you have them honed, have the surface that bolts to the block shaved down a tiny bit so that you can align hone them back to the factory size. if you dont shave them down first, you'll have to enlarge them beyond factory spec. any good machine shop will be able to explain and perform this process for you.
BrokenRex is offline   Reply With Quote
Old 07-15-2008, 10:17 PM   #14
Bkkfarang's Avatar
Ride:  95eg extreme single cam / 06jazz hks turbo soon/
Rep Power: 11 Bkkfarang is a jewel in the roughBkkfarang is a jewel in the roughBkkfarang is a jewel in the rough
sound like the right way to do it to me
Bkkfarang is offline   Reply With Quote
Old 07-15-2008, 10:49 PM   #15
Sounds like a plan to me, I planned on doing a straight hone anyways but didn't think to have them shave the tops, great response. Just the kind of info im looking for, thanks.
Old 07-15-2008, 10:51 PM   #16
Any body have any answers on the p2t?
Old 07-15-2008, 10:55 PM   #17
Is there any other magic I can do to the block at the mach. shop, like pnp oil orphises or anything why its there?
Old 07-15-2008, 10:58 PM   #18
Meanwhile im starting the Nip/Tuck!!!!
Old 07-16-2008, 12:03 AM   #19
Old 07-16-2008, 12:04 AM   #20
Old 07-16-2008, 12:11 AM   #21
Goin to cali to get did.
Old 07-16-2008, 12:31 AM   #22
Bkkfarang's Avatar
have typer oil squirters added . replace the sleaves or pin the block to prevent cyclinder walk . have all sharpe egdes deburred .
Old 07-16-2008, 04:27 AM   #23
I'll be back...
B16RacerN2NR's Avatar
Ride:  06 Mazda 5, 91 Civic DX
Rep Power: 148 B16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond repute
B16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond repute
Send a message via AIM to B16RacerN2NR myspace
You need the p72 to control the secondary butterfly. The p2t doesn't have that function/feature.
Champs Once Again Baby!!! GoLakers!!!
B16RacerN2NR is offline   Reply With Quote
Old 07-16-2008, 03:33 PM   #24
i failed to mention the head is of a 99 b16a. and Im using the stock harness wich is the same as the SI. (vtec, knock sensor,crank angle, etc) what do you think?
Old 07-16-2008, 03:35 PM   #25
Oh yeah and the sleeves is what i meant by getting did, there in the pic. And are oil squirters worth it ive heard both no and yes.
Forum Jump
SEO by vBSEO 3.2.0
 | a SkeyMedia Network site
