Ride: 2000 Civic Si , 1996 Integra GSR
I originally picked up a 96 GSR with 170k+ on it with intentions of rebuilding the motor and boosting it, but now the more I think about it, would I be better off just finding a lower mileage swap?
I'm just concerned about the possibility of weakened components like rods, etc
2000 Civic Si: soon to be supercharged B18C1/ITR powered 1996 GSR: daily driver 1996 DX hatch: gf's B20vtec powered dd 1994 Civic EX coupe: sold, wrecked and scrapped ![]() current dream Honda: UKDM Accord CTDi-R Buffalo, NY- 2ft of snow in October
#2 | ||
Honda Enthusiast
Ride: '94 EG sedan w /Z6, '97 EK hatch
If you are willing to spend the money, I would replace things such as the bearings at the very least, then take it from there. Heck, while I was in there, I would check to see if everything checked out and oh, I don't know...get some aftermarket rods and pistons for it, give it a fresh hone and then have it be even more ready for boost.
Those are just my two cents. I personally would not get rid of it though, as you will most likely end up paying a heck of a lot more on a different engine instead of building this one up a bit.I am sure others will have their opinions as this is just mine. Best of luck.
Max? There is no max. Max just means you gave up. This is my thread: http://hondaswap.com/engine-building...g-wind-110848/ My for sale/trade thread http://hondaswap.com/parts-sale-trad...1/#post1048406 Quote:
#3 | |||
The Kicker of Elves.
What's your power goal? You shouldn't have any problems with 300whp or less. Over that and you'd want to replace the internals with forged units anyway.
Don't misinterpret what I say. Quote:
Ride: B20/vtec DC, Nissan Xterra SE, 16ft Caprice Skiff
if you are going to boost it regardless of what you decide, then i would definitely say re-build the engine you have! buying another engine with less miles is nice and all, but really you want stronger internal parts no matter how many miles you have. if you are definitely boosting it anyways.
#5 | |||
^^^A stock GSR is good to 350whp with a good tune and proper fuel.
#6 |
if your going to have the motor appart u might aswell just throw some quality parts in there, and clean up things like the crank and block and have a 0 miles bottom end. then its like pretty much having a new motor. you can get quality forged rods and pistons for like 700 bucks, some minor machine work, and some small parts an your off to the races with a solid motor. build it!
#7 |
ADD Member
i would feel safe with only 170,000 miles, unless the motor was abused and molested early on
you never actually win, you just do a lil better each time"White paint wetter than new rain" |
#8 |
well either way i don't plan on going with rods & pistons, it's only going to be supercharged @ ~10psi, probably well below 350hp. I just really don't want to be sinking that kind of $$ into it if I'm not going to be boosting the crap out of it, especially when that same $ could better be spent elsewhere like a down payment on a house.
I'm more wondering which would be better financially- I could either drop the $ to rebuild the motor I have now or sell the one I have now which would pay for a good chunk of a lower mileage swap that *should* be fine in stock form I'm thinking even if I do most of the labor myself, the cost of bearings, rings, possibly having crank turned, etc will be more than the difference of what I could theoretically sell my engine for and what I could get a lower mileage one for. Not to mention the pain in the ass and downtime factors whereas I could just yank the existing engine and drop in a different one... I'm halfway tempted to just say f it, throw the blower on this engine and see how long it lasts then worry about it later... or sooner...
#9 | |||
Ah, finally someone with the common sense to realize that there's no point in spending thousands of dollars on an engine.
It'll cost you $500-1000 to rebuild your current engine. "Should be" is never what you want with things like this. Just because an engine has lower mileage doesn't mean the previous owner didn't beat the living piss out of it. Rebuild your current engine. Why are you going to have the crank turned? It's a Honda, the crank's already balanced and already has a journal coating that independent shops can't match.
#10 |
i dunno, just figuring on worst case scenario once i get it torn down if journals are scored then the cost of the rebuild kind of skyrockets
if i do decide to do the rebuild, should I really do a quick clean up hone regardless? and I understand why rings need to be done ie- loss of compression, oil burning, etc but how do you know when bearings need replacing?
#11 | |||
-Never assume anything when you're building an engine. If the crank is messed up, you're better off finding another one that isn't and then getting your main caps align bored.
-I would. I'd even get a .020" over-bore to ensure perfectly round cylinders. -You can tell when bearings need to be replaced by taking them out and looking at them. If they're really shiny or scored up, they need to be replaced. ![]()
#12 |
if i go .020 over then i'll have to get pistons tho right?
#13 | |||
Indubitably.
#14 |
Ride: 1997 dx coupe (2300lbs), 2000 front end conversion. built b16 turbo
bearings are not that expensive if your gonna have the motor broke down anyway. you may as well put the extra $ into it while your there. or you might wish you would have later on.
once you enter into the speed ring, you only want more. its addicting. have fun!
Live for somthing or die for nothing..... |
| Lower Half of Engine Rebuild | walter | Engine Building | 3 | 09-07-2006 03:23 PM |
| crx si engine rebuild kit?? Where to find one | Jdubspeeds | Engine Building | 1 | 01-19-2004 07:07 AM |
| mileage reading after engine swap | krossoverr33 | HYBRID -> EG-EK / DC | 2 | 07-25-2003 02:19 AM |
| Swap or Rebuild?? | standdstill | HYBRID -> EG-EK / DC | 16 | 07-18-2003 12:52 AM |
| Where Can I Find An Engine Rebuild Kit. | Moonlight Illusion | Engine Building | 1 | 04-20-2003 10:14 PM |
