Rod Bearings & Main Bearings
Old 01-07-2003, 07:09 PM   #1
Rep Power: 16 Slimtadder is off the scale
Send a message via ICQ to Slimtadder Send a message via AIM to Slimtadder
Thumbs up
I need help do I stay with OEM or go aftermarket? It's a B16, with I hoping 200+ housepower.
Thanks
Slimtadder is offline   Reply With Quote
Old 01-07-2003, 08:02 PM   #2
GNU/Linux Evangelist
lsvtec's Avatar
Ride:  The Cheapest Road Bicycle I could get
Rep Power: 69 lsvtec is on a distinguished road
OEM
v3sw7+9Chw6ln3pr7Ock4ma9w3TXm3l7GDF i7Ce6+8t4MNb8Oen6g6RAOa26s5MRp6 hackerkey.com
lsvtec is offline   Reply With Quote
Old 01-07-2003, 08:29 PM   #3
OEM why? I know normally it's the best way to go but, is like Napa's shit o.k or no?
Thanks
Old 01-07-2003, 08:54 PM   #4
Ride:  93 del Sol Gas sipper
Rep Power: 101 asmallsol is a jewel in the roughasmallsol is a jewel in the roughasmallsol is a jewel in the rough
People think that all of honda's shit is crap, and when they start "tunning" there stuff, they replace it with parts that actually have worse quality. True a dx air box is designed to do its purpase and be quiet instead of just being for letting air in. Yes, goind with CAI will help. However, Honda is one of the best engine designers in the world and alot of there stuff that has no diffrance in ride comfort, safety, reliablility, and emmissions they will put the best stuff in there engines. Stuff like bearings, and ignition systems, honda only goes with the best and you will have a tuff time finding better. Also with stuff like tranny fluid, the honda MTF is the best you can run in hondas because honda designed it to work best with there trannys
(sorry to go so far off subject but you know what i am saying)
Collin
Material Science and Engineering
Michigan Technological University
Old 01-07-2003, 08:57 PM   #5
Rep Power: 23 chet is off the scale
Send a message via AIM to chet
use OEM Honda for bearings.
<a href=\'http://www.geocities.com/coker_boy/honda.html\' target=\'_blank\'>The Green Machine</a>
chet is offline   Reply With Quote
Old 01-07-2003, 09:13 PM   #6
Where do I find the color codes for the bearings in my B16?
Thanks
Old 01-07-2003, 09:18 PM   #7
Rep Power: 20 prawjEKt Cx will become famous soon enough
Send a message via AIM to prawjEKt Cx
use OE bearings, but when you get into your bolts and shit, go arp
prawjEKt Cx is offline   Reply With Quote
Old 01-07-2003, 09:22 PM   #8
Rep Power: 16 5genracer is off the scale
there is a set of numbers on the side of the block for the main bearings, and letters on the crank. Match the two up and call the honda dealer, they will know what to do. There are numbers on the rods too.
02 Sebring Silver / Red S2000
5genracer is offline   Reply With Quote
Old 01-07-2003, 09:50 PM   #9
Rep Power: 0 judonoh is off the scale
I personally like clevite 77 bearings. Standard makes some good items, but some are crap you just never know. OEM are good also
judonoh is offline   Reply With Quote
Old 01-07-2003, 11:05 PM   #10
lsvtec's Avatar
After reading this:
http://www.hondaswap.com/forums/index.php?...t=ST&f=7&t=4173
I wouldn't touch clevite bearings. OEM are the best.
Old 01-08-2003, 04:44 AM   #11
Rep Power: 17 chris is off the scale
Send a message via AIM to chris
i also would go with OEM bearings, tried and tru. as for colors/size its all in the helms manual, tells u which ones u will need according to the #'s on the crank and rods.
Used performance parts straight from Japan/road race questions: <a href=\'http://www.rcrewracing.com\' target=\'_blank\'>www.rcrewracing.c om</a>
chris is offline   Reply With Quote
Old 01-08-2003, 05:19 AM   #12
RETIRED
pissedoffsol's Avatar
Ride:  Electric Scooter
ACL owns
ACL 780 Duraglide Main Bearings Blanco Engine Building 8 09-11-2008 03:32 PM
ECU Pinouts pissedoffsol Reference Materials 4 11-21-2007 10:46 AM
Building Roll Cage brian1 General Tech and Maintenance 17 05-22-2004 05:12 AM
main and rod bearings Tenzodelsol General Tech and Maintenance 6 05-13-2004 02:44 PM
where to buy main bearings and rod bearings KFBhonda Engine Building 13 01-13-2004 12:13 PM
