Setting Tming,w/ Head Replacement
Old 04-22-2003, 01:37 PM   #1
Rep Power: 0 EstiLoFeRiO is off the scale
K guys, i really need help, I just replaced my headgasket, and i havent put in the valvetrain or anything yet. How do I set the timing again to put the timing belt on right? Did the pistons need to be in any position? Because i just bolted the head back onto the block without even noticing. What about the camshafts when i put them back in? Anyhelp will be appreciated or any sites explaining this..
EstiLoFeRiO is offline   Reply With Quote
Old 04-22-2003, 03:55 PM   #2
Any1?? All help will be appreciated... I know we have some hardcore enginebuilders in here.. :-)
Old 04-22-2003, 08:16 PM   #3
Rep Power: 15 tomtom is off the scale
Send a message via AIM to tomtom
Talking
u need to line the crankshaft up with the camshaft
make sure cylinder 1 is at tdc
then line the cam gears
email me 4 more info
tomtom is offline   Reply With Quote
Old 04-24-2003, 11:22 PM   #4
Banned
Rep Power: 0 CriztheWiz is off the scale
Send a message via AIM to CriztheWiz
what motor is it? You know if you do it wrong you can really fuck up your motor.
CriztheWiz is offline   Reply With Quote
Old 04-24-2003, 11:49 PM   #5
B16
B16's Avatar
yes, set the bottom end to TDC, you should see the white mark on the crank pulley lined up with the pointer on the block. (not the white ones near the red one)
next, set your cam gear arrows UP, then slip on the timing belt, make sure the slack is on the side towards the rear of the car, and tight towards the front of the car. then loosen and re-tighten the tension pulley. i've only done this on my B16, but i assume its the same for the other honda motors.
2004 BMW 325i
2000 Mercedes Benz ML 430
Help on head Replacement on a B18c1? hondamidnighter HYBRID -> EG-EK / DC 1 03-06-2004 12:45 AM
B18A1 Can I add VTEC? psychochicken HYBRID -> ED-EF / DA 9 01-19-2004 10:31 PM
I think I found it! B-18Hatch Members' Lounge 8 08-08-2003 12:12 AM
Wtb Head For A D15b2 Or Good Replacement Motor ssgdgun Parts: For Sale/Trade/Wanted 8 05-01-2003 05:34 AM
