Sir I Swap
Old 04-26-2003, 11:43 PM   #1
Rep Power: 0 jonnys is off the scale
I'm in the middle of swapping a b16a into my 91 civic Si! I got most of the simple stuff, intake, header, plug and plug wires, clutch and flywheel. I wanted to get about 20-40 hp more, but stay N/A. I would like to stay around a grand???? Is this possible and if so what would be the easiest way to do this!!!!!!! If anybody could help I would be eternally grateful?!?!?
jonnys is offline   Reply With Quote
Old 04-26-2003, 11:52 PM   #2
Member of the 20 nut club
E_SolSi's Avatar
Rep Power: 527 E_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond repute
E_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond repute
cams and cam gears
maybe a VAFC or a hondata
МОΛΏΝ ΛΑΒΈ
Old 05-11-2003, 09:13 PM   #3
Hmm...staying NA and gaining 20-40hp for 1k, I would definetly say Hondata for tuning reasons and I would also way CTR cams with some cam gears that only allow adjustability of +/-5 degrees. You might also consider making your car run a little cooler and taking some weight off of it. Things like the heater under your dash, more water in your coolant, thermo wrap your intake, header wrap your header, cap your plugs properly, bump timing, cut coolant lines to TB (i mean take them off and connect the two together) take your AC out & Power steering, etc....
By freeing up some weight your going faster down the 1320 stretch. And also there is less rotating assembly on your crank.
But for right now I would go with oem R cams and hondata and make sure to tune the little beast out
Milan
13.3@103 MT's &amp; Gutted
-Project 5 - Motor A (???)
H22AdelSol's H22A swap guide. H22AdelSol HYBRID -> BA-BB /CA-CD 14 08-04-2008 09:53 PM
Del Sol S D15B7 to D16y8 swap question oakley2002@cox.net HYBRID -> EG-EK / DC 1 01-21-2004 01:32 PM
2nd gen Integra Swap Info pissedoffsol Swap Articles 0 01-12-2004 02:16 AM
1st gen Integra Swap Overview (da) pissedoffsol Swap Articles 0 01-12-2004 02:15 AM
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
