skunk 2 cams and gears
Old 09-24-2006, 05:31 PM   #1
Rep Power: 0 pistonkiller is on a distinguished road
Default skunk 2 cams and gears
i have a completely worked head skunk 2 everything. what is the best setting on my cam gears so i can get the best results out of them. thanks
pistonkiller is offline   Reply With Quote
Old 09-25-2006, 06:36 PM   #2
GNU/Linux Evangelist
lsvtec's Avatar
Ride:  The Cheapest Road Bicycle I could get
Rep Power: 69 lsvtec is on a distinguished road
That isn't something that we can just tell you. In order to set them well you need to put the car on the dyno and see what works best. On a side note, be careful with the Skunk2 valves/retainers, they will need to be lashed very frequently.
v3sw7+9Chw6ln3pr7Ock4ma9w3TXm3l7GDF i7Ce6+8t4MNb8Oen6g6RAOa26s5MRp6 hackerkey.com
lsvtec is offline   Reply With Quote
Old 10-14-2006, 08:01 AM   #3
Rep Power: 9 herminshs is off the scale
What do you mean by "lashed" often?
herminshs is offline   Reply With Quote
Old 10-14-2006, 12:21 PM   #4
lsvtec's Avatar
You will have to adjust the clearances between rocker arm and retainer much more often than with stock retainers.
Old 10-14-2006, 02:13 PM   #5
ahh, yeah, you got that right buddy
Old 10-15-2006, 12:36 AM   #6
GSRCRXsi's Avatar
Rep Power: 88 GSRCRXsi is a glorious beacon of lightGSRCRXsi is a glorious beacon of lightGSRCRXsi is a glorious beacon of lightGSRCRXsi is a glorious beacon of light
lash is actually the clearance between the rocker and the cam
91 CRX si
95 Integra LS
Originally Posted by 90 accord
i have a lady, of over a year and a half now, and she likes the plug more
Old 10-16-2006, 11:48 AM   #7
lsvtec's Avatar
You're right, but what I meant was that the Skunk2 retainers whift a lot causing a bigger gap in clearance.
B Series Cam Guide JDMilan Reference Materials 35 04-13-2007 09:26 PM
How to build a "reliable" lsvtec/b20vtec bambam General Tech Articles 2 07-02-2006 05:48 AM
FS:Comptech Race Header, Skunk stg 3 Cams, B17 w/ctr pistons, lots of vtecjj Parts: For Sale/Trade/Wanted 8 03-22-2006 08:55 PM
Cams and cam Gears khai_tuan_nguyen Engine Building 11 01-30-2004 07:06 PM
Setting Cam Gears On Jun Stage 3 Cams colorpros Engine Building 4 01-29-2003 03:17 PM
