Skunk2 Camshafts
Old 11-02-2003, 11:45 PM   #1
Rep Power: 17 noobvang is off the scale
I've got some camshafts that I'm not sure what they are.
They look like skunk2 but seller said that they were CTR(intake) and ITR(exhaust) camshafts.
I know for sure that there not CTR/ITR cams is that they don't have any of the rings/cuts at the end of the cams. Seller is not sure either after I told him this. He said that he sent his head in to King Motorsports and this is what it came back with. Thats what if says on his paperwork too. So.....
I was wondering if any of you guys can tell me how to tell the difference in the cams. Or how to just ID the cams if they are Skunk2.......the stages too if you know.
Thanks.
96 LX 4dr. with B18a, PR3 pistons, B16 head w/ port 'n polish to intake, CTR intake/exhaust cams, ITR IM, CTR TB, Hondata IM gasket, RC 310cc injectors, Denso Iridum plugs, Skunk2 valve springs/retainers, Excedy race clutch, ACT streetlight flywheel, Walbro 255 fuel pump, GSR tranny, and Tanabe Super Racing Medalion...., next is Header and VAFC.
Best run on 1320:
14.5 @ 94.5mph street tires
14.4 @ 94mph small slicks :P
98 Yamaha R1
noobvang is offline   Reply With Quote
Old 11-03-2003, 11:55 AM   #2
Rep Power: 19 ek9r is off the scale
Send a message via AIM to ek9r
sounds shady. . . . . only real way to tell is use a micrometer, record your readings of all the lobes, and contact skunk for their specs. id find another seller personally. been there, done that, not worth the headaches . . .
suck it sideways sister
ek9r is offline   Reply With Quote
Old 11-03-2003, 11:57 AM   #3
B16
B16's Avatar
have any pics?
2004 BMW 325i
2000 Mercedes Benz ML 430
Old 11-03-2003, 01:18 PM   #4
Wish I took pics when out of the car.
Since it didn't have any engravings/markings what so ever, I just assume that they were stock cams. I bought them for about 100 bucks so no one gets riped, mostly because I don't have any cams to spare.
.......Well, heres to total story:
Dude sells me a B16 head, has work done to it.
Intake P&P................................ ........................varified
Skunk2 Valve spring/retainers.......................... ..varified(sorta, retainers look like skunk2s)
LS/Vtec machine work............................... .........varified
UR cam gears.............................. ......................varified
CTR/ITR Cams............................... ....................In the process
Well, I bought all this for 900 bucks, good deal?
Now I'm wondering about the cams, motor is in car now. Not sure if its aftermarket cause the dude upgraded the valve springs/retainers.
Reason I'm asking if its skunk2, is that its the only company that makes their cams look like stock ones.
All black and silver at the lobes. Is there any stock cams that has no markings/rings etched on them.
For now, I'm just assuming stock cams(gen1 of JDM b16s). Cams have no markings what so ever on them.
Best run on 1320:
98 Yamaha R1
Old 11-03-2003, 04:58 PM   #5
B16
B16's Avatar
email skunk2, there is a stamping inbetween some of the lobes that can tell you if they are skunk2 or not, i forget what they are though. but i do know they are there.
2004 BMW 325i
Old 11-03-2003, 06:09 PM   #6
Ride:  93 del Sol Gas sipper
Rep Power: 101 asmallsol is a jewel in the roughasmallsol is a jewel in the roughasmallsol is a jewel in the rough
Find out what type of valve guide maching they did. If they did kurning, then I would redo it and replace the valve guides. (kuring is where they stick a drill like bit down the guide, it spins and lifts up some metal almost like a thread. This does not last at all)
Collin
Material Science and Engineering
Michigan Technological University
B Series Cam Guide JDMilan Reference Materials 35 04-13-2007 09:26 PM
Installing Skunk2 Harms Way Engine Building 1 06-14-2004 02:15 AM
got skunk2 camshafts for xmas h22bubbleback General Tech and Maintenance 7 12-26-2003 03:35 AM
Eagle rods and Je 11.5:1 pistons tnsxsear Parts: For Sale/Trade/Wanted 20 11-03-2003 12:47 PM
Skunk2 Vs. Spoon Camshafts wisemansoji Engine Building 3 05-11-2003 05:20 PM
