K-5eRiEs Is ThE 5HiT.....
Ride: Integra,Civic
Hey how you guys doing im having trouble with the skunk2 throtle body its a 70mm I put on a type r motor its fully built n pushing 20 psi now when i turn on the car it idle normally after accelarating it a couple of time it stay stuck and rev high i dont knoe wat to look for, i dont know if i should check the map sensor or the throttle positioning sensor how ever you call it ...lol......
Führer Mod
TPS.. on the stock throttle body there is a idle adjustment screw.. not sure if there is one on the skunk TB
#4 | |
I wear stretchy pants
Ride: chevy s-10
does it get stuck sometimes? or all the time. It could be your cable is too tight. if not then def. check you tps readout at WOT to make sure its seeing the proper voltage
#5 |
Ride: Integra,Civic
the cable is lose but i will losin it a lil bit more just in case , n the tps is that the sensor thats goes on the side if is that im not sure cause im using a porsh tps. N wat is a normal voltage for the tps
#6 | |
Ride: chevy s-10
huh? your using a porsche tps on a honda? the tps is the ensor on the throttle body. I has 3 wires going to it. red, green and sometihng else.
damn beat me to it Blanco. __________________
#7 | |
Ride: chevy s-10
#8 | |
Ride: Integra,Civic
Yes im using a porsh tps cause the stock wasnt going to help......i just need help on how to set the voltage n wat do i use to measure it . |
#9 | |
Ride: chevy s-10
besides the headache how do you benefit from the porsche tps?
![]() i cant tell how to set it because its not a honda TPS. for all i now it could read something totally different at WOT than the HOnda one. __________________
#10 |
you get the BRAKE
Get a 3 bar map sensor from a GM. Don't adjust that idle screw too much either. Try spraying throttle-body cleaner in it while moving the butterfly (throttle) open/closed. The procedure is actually on the back of the can, if you do buy it. Just follow the procedure. Also, do not loosen up your throttle cable. Make sure it is tight at the same time make sure the butterfly is completely closed at 0 throttle. If it is too loose, your pedal will stick after you hit full throttle. Happened to me with my integra.
eg hatch (jdm b16) sold 1999 Yamaha YZF R6 (modded) http://hondaswap.com/engine-building...ow-pics-102486 sold Last edited by LS_VTEC; 01-09-2008 at 01:45 AM. |
| New Skunk2 Sport Shocks for the EF Civic | skunk2.com | Parts: For Sale/Trade/Wanted | 0 | 10-24-2007 03:00 PM |
| body filler over primer? | ssl2k | Body / Exterior / Interior / Cosmetics | 20 | 05-16-2004 09:35 PM |
| Fs: Itr Throttle Body | pills_PMD | Parts: For Sale/Trade/Wanted | 4 | 02-26-2003 12:24 AM |
| Oh Crap, Problem With Skunk2 Im | lsvtec | Engine Building | 9 | 02-15-2003 12:49 PM |
