Skunk2 Vs. Spoon Camshafts
Old 05-10-2003, 03:35 AM   #1
Rep Power: 16 wisemansoji is off the scale
Want some info whats best bang for buck, for a b16a2 Spoon or skunk2 camshafts
wisemansoji is offline   Reply With Quote
Old 05-10-2003, 11:01 AM   #2
GNU/Linux Evangelist
lsvtec's Avatar
Ride:  The Cheapest Road Bicycle I could get
Rep Power: 69 lsvtec is on a distinguished road
The Skunk2's. You are going to pay way too much for the Spoon's simply because they say Spoon.
v3sw7+9Chw6ln3pr7Ock4ma9w3TXm3l7GDF i7Ce6+8t4MNb8Oen6g6RAOa26s5MRp6 hackerkey.com
lsvtec is offline   Reply With Quote
Old 05-10-2003, 02:01 PM   #3
Member of the 20 nut club
E_SolSi's Avatar
Rep Power: 541 E_SolSi has a reputation beyond repute
E_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond repute
spoon or mugen anything are almost never worth it
dont get me wrong they are great parts but for the money you can usually get better shit
МОΛΏΝ ΛΑΒΈ
Old 05-11-2003, 05:20 PM   #4
I would go with the Skunk cams, Spoon is a lot more $$ plus the skunks will net more hp here is a comparison of the two
Following Cams Measured at 1mm of lift:
Skunk2 Stage 1
Int-252 dur. / 11.5mm lift
Exh-249 dur. / 10.8mm lift
Valve Springs to be used: Stock B16A/GSR if using stock 8200 re-limit. Integra Type-R if using rev limit over 8200rpms. Skunk2 Valve Springs can also be used.
Description: These are very underrated cams. They do cost around $100-$200 more than the Type-R cams but they also offer much more duration and will give more power than the Type-R cams. Similar power range of Type-R cams but stronger throughout the power band. This is a great set of cams for a budget minded B16A owner. These cams have stock idle characteristics. I would recommend using Skunk2 cam gears with these cams.
Spoon Sports
Int-256 dur. / 11.5mm lift
Exh-245 dur. / 11.1mm lift
Valve Springs to be used: Integra Type-R. These cams are wild enough that you should not be using the low 8200rpms rev limit. If using these cams past 8800rpms(why would you) I would think that Port Flow or even Toda valve springs would work but I don’t think these cams will make much power after 8400rpm.
Description: Another somewhat rare cam. Will show definite gains over that a Type-R cam and very good gains on a stock B16A/GSR motor. Stock idle characteristics from the few users I have seen use them. I would recommend using Spoon cam gears with these cams.
Skunk2 Stage 2
Int-266 dur. / 12.3mm lift
Exh-262 dur. / 11.8mm lift
Valve Springs to be used: Skunk2 preferred but Port Flow will work as well. These cams are wild enough that you should not be using the low 8200rpms rev limit.
Description: The new top dog of the cam world. This will become the most common aftermarket (non OEM) cam in the US when they start getting distributed more. These have a very similar power band as the JUN Type 3, with less cost and better reliability (I said the “r” word). Not huge midrange but very good gains from 7000rpms all the way to 9000rpms(peak is usually around 8000-8200rpms). These cams have stock idle characteristics, thus making them the ultimate street/strip cam. I recommend using Skunk2 cam gears with these cams.
Skunk2 Stage 3
Int-270 dur. / 12.8mm lift
Exh-279 dur. / 11.8mm lift
Valve Springs to be used: Skunk2.
Description: A race only cam. Not to be used on the street, if they are you should pull the head every oil change to make sure everything is OK. This cam makes huge top-end power gains but still retains stock idle characteristics (weird). This cam is or has been used by Skunk2’s drag racing team and Speed World Challenge team as well. I recommend using Skunk2 cam gears with these cams.
If you want a more complete list of most cams out there I can post it on this forum, just let me know.
Milan
13.3@103 MT's &amp; Gutted
-Project 5 - Motor A (???)
B Series Cam Guide JDMilan Reference Materials 35 04-13-2007 09:26 PM
got skunk2 camshafts for xmas h22bubbleback General Tech and Maintenance 7 12-26-2003 03:35 AM
Skunk2 Camshafts noobvang Engine Building 5 11-03-2003 06:09 PM
Eagle rods and Je 11.5:1 pistons tnsxsear Parts: For Sale/Trade/Wanted 20 11-03-2003 12:47 PM
