Facebook Twitter
sohc zc with z6 head???
This is a discussion on sohc zc with z6 head??? in the Engine Building forum
Well to start off i have a full running sohc zc. I also have a full d16z6 with a spun rod bearing. My question is do you have to bore out the oil passages in the block to accommodate for the extra oil flowing from ...
Old 03-30-2012, 08:40 PM   #1
Default sohc zc with z6 head???
Well to start off i have a full running sohc zc. I also have a full d16z6 with a spun rod bearing. My question is do you have to bore out the oil passages in the block to accommodate for the extra oil flowing from the v-tech head? Is this worth the work considering it will we for my daily driver? Thanks for the help.
zackzerr is offline   Reply With Quote
Old 03-31-2012, 03:17 AM   #2
autox 89 dx's Avatar
No drilling at all. You just remove the oil jet plug on the block next to the 2 and 3 cylinder under the head then install z6 head. You have to run a p28 ecu and get a vtec sub harness and a jumper harness if your car is odb0. You will also need a odb1 dizzy. I ran a zc mini me in my 91 si and it was fun to drive and when I switched to a complete z6 the zc was more powerfull in my opinion .
autox 89 dx is offline   Reply With Quote
Old 03-31-2012, 03:39 PM   #3
ya i have the p28 and full obd1 harness. Im in the process of switching harness from headlight to tail light. It is goin into a 89 hatch. do you know what kinda of power range in looking at? i heard im looking at around 130ish
Old 04-03-2012, 03:27 PM   #4
All you need to switch is the engine harness.
98EkSi is offline   Reply With Quote
Old 04-05-2012, 05:35 PM   #5
i have a boomslang jumper harness but two wires are broken at the clip. how would it work if i was to just switch the engine harness? where they clip together at the fire wall is different i thought
d16z6 head and d16y8 head(sohc vtec) triniDEMON HYBRID -> EG-EK / DC 6 09-09-2005 08:28 PM
CRX 89 SI SOHC HEAD fongman Parts: For Sale/Trade/Wanted 0 05-14-2005 11:52 PM
fs:sohc zc and y8 head cavrx Parts: For Sale/Trade/Wanted 2 05-27-2004 10:18 PM
In Need of SOHC Head gomezkun Parts: For Sale/Trade/Wanted 5 11-18-2003 12:38 AM
SOHC HEAD pappa Engine Building 1 09-05-2003 05:58 AM
© 2001-2013 HondaSwap.com
