Stroker Kits For B16a?
Old 03-27-2003, 10:10 AM   #1
Rep Power: 14 disamis is off the scale
what is the possible stroker kits for B16a? can we use B16b stroker kit(http://www.inlinefour.com/spoon18lstro.html) for B16a? in daily use;
what is the possible problems after doing this modification?
A red rex from Ankara
<a href=\'http://www.hondam.com/galeri/05.php\' target=\'_blank\'>http://www.hondam.com/galeri/05.php</a>
disamis is offline   Reply With Quote
Old 03-27-2003, 11:37 AM   #2
Rep Power: 20 TRuggiero_ is off the scale
I'd say no. Only because it's built for a B16B. Even though the bore and stroke of the B16A and B16B are identical, there must be a problem somewhere other wise they would say that it'll fit and get more sales. You can get a Toda stroker kit for a B16A for like 2k.
Whenever you do something like a stroker kit, you will need, a much, much better valve train. New cams, valves, retainers, springs, cam gears, etc. I'd also improve my fuel delivery.
This is my civic. There are many like it, but this one is mine.
My civic, without me, is useless. Without my civic, I am useless.
Think your Cool? Take the <a href=\'http://www.sailinganarchy.com/general/2002/cool_test.htm\' target=\'_blank\'>test!</a>
TRuggiero_ is offline   Reply With Quote
Old 03-27-2003, 12:09 PM   #3
Rep Power: 44 MaaseyRacer is an unknown quantity at this point
Send a message via AIM to MaaseyRacer
if you want more displacement in a b16a get a b17 crank...
2004 Toyota Tacoma
3.4L V6
TRD Package
4WD
MaaseyRacer is offline   Reply With Quote
Old 03-27-2003, 12:33 PM   #4
88 C1V1C 53D4N DR1V3R
saturn_boy96's Avatar
Ride:  2006 Suzuki Aerio
Rep Power: 31 saturn_boy96 will become famous soon enough
Send a message via AIM to saturn_boy96 Send a message via MSN to saturn_boy96 myspace
yeah, the b16a and b16b may seem similar but are actually from two completely different blocks.
the b16b is basically a destroked b18c5. its the 1.6 liter version of the integra type r motor. thats why the kit wont fit, the blocks have two different deck heights.
saturn_boy96 is offline   Reply With Quote
Old 03-28-2003, 07:07 AM   #5
what is the other stroker kits(toda racing) for B16A?
can you tell the mild modifications(NA) for street use?
Old 03-28-2003, 11:07 AM   #6
GNU/Linux Evangelist
lsvtec's Avatar
Ride:  The Cheapest Road Bicycle I could get
Rep Power: 69 lsvtec is on a distinguished road
Give that last post another try, I am not sure that is English.
v3sw7+9Chw6ln3pr7Ock4ma9w3TXm3l7GDF i7Ce6+8t4MNb8Oen6g6RAOa26s5MRp6 hackerkey.com
lsvtec is offline   Reply With Quote
Old 03-28-2003, 11:19 AM   #7
Eagle also has a stroker kit for B16A, probably a shyt load cheaper then TODA.
Old 03-28-2003, 12:10 PM   #8
K2e2vin's Avatar
Ride:  88 Honda Civic HB
Rep Power: 150 K2e2vin has a reputation beyond reputeK2e2vin has a reputation beyond repute
Send a message via AIM to K2e2vin  FaceBook
if you use a b17 crank then youll have to get some new rods too. you dont need to change all those stuff just because youre getting a stroker kit. i would rather keep the b16a's stroke how it is, mainly b/c of its geometry and its ability to rev high. if you just want a larger displacement, just get a b18c or use the b16 head on a ls/vtec engine. the hondas also come with strong cranks so i would hate to throw away a pretty good crank.
i just did some calculations for the b17 crank; youll also need a b17 rod or some other 131.87mm rods. so ill just be a b17. the r/s ratio is 1.62.
1988 Honda Civic Standard-more mods than I want to list
1992 Honda Accord LX
1996 Toyota Avalon-Spun bearing, for sale.
Terrorists have successfully attacked our imagination.
RIP
Jon Eban Nie, August 31, 1991 - May 7, 2006
Y-Daniel Siu Eban, September 7, 1986 - May 7, 2006
K2e2vin is online now   Reply With Quote
Old 03-28-2003, 03:27 PM   #9
i wanna know if someone else made stroker kits other than "toda racing" for B16A?
what is the common problems of making a Ls-vtec?
Old 03-28-2003, 03:42 PM   #10
lsvtec's Avatar
I think that Eagle makes a stroker kit for that engine, I don't know if it will just "drop" in.
The most common problem I have seen with an LSVTEC is the builder attempting to skimp. It leads to blown engines. Other than that I don't know of any problems.
Old 03-28-2003, 03:52 PM   #11
Rep Power: 44 Domeskilla is off the scale
Crower makes stroker kits also.
For all your air suspension needs <a href=\'http://www.ultimatesporttruck.com\' target=\'_blank\'>Three Rivers Ultimate Sport Truck</a>
**There are many misconceptions of air ride and handling. A lot of bullshit spread, please PM if you wish to put air on your car/truck. You will get the 411. There ARE ppl who race with air ride, just have to know how to install it right.**
Domeskilla is offline   Reply With Quote
Old 03-28-2003, 03:56 PM   #12
do you know the web site of the firm called "Eagle" ?
Old 03-28-2003, 03:58 PM   #13
Originally posted by disamis+Mar 28 2003, 04:01 PM--><div class='quotetop'>QUOTE(disamis @ Mar 28 2003, 04:01 PM)</div><div class='quotemain'> <!--QuoteBegin-lsvtec@Mar 28 2003, 03:47 PM
The most common problem I have seen with an LSVTEC is the builder attempting to skimp. *It leads to blown engines. *Other than that I don't know of any problems.
do you know the web site of the firm called "Eagle" ? [/b][/quote]
Eagle has been around for years and has been making rods for domestics for years and i dont think they have a website. Its not listed on any packaging of theirs and i can't find ti searching the web. www.theoldone.com Endyn deals with Eagle, maybe they can get you the info on their stroker kits.
Old 03-28-2003, 03:59 PM   #14
lsvtec's Avatar
If I still have the documentation that came with my rods I will post their phone number when I get home tonight.
Old 03-28-2003, 04:20 PM   #15
what are the benefits of using skunk2 intake manifold with stock cams in B16a?
http://www.skunk2.com/engine/manifold_dyno.htm
Stroker Kits for H-series lude9593 Engine Building 3 07-23-2004 08:50 AM
Stroker Kits Worth The Money? XZILER8 Engine Building 6 05-26-2003 03:18 PM
Stroker Kits? 93tegh22 Engine Building 0 05-06-2003 10:25 PM
Crower Stroker Kits EdrikLongtail Engine Building 18 04-28-2003 08:22 PM
Stroker Kits civic_ferio General Tech and Maintenance 9 04-07-2003 12:31 AM
