This is a discussion on Stroker Kits Worth The Money? in the Engine Building forum
Are stroker kits worth the money?
I know that's a very broad question, but I'm just curious about what kind of gains can be expected?
The main focus of this is for a h23a1.
What are some sites that I should look into to gain ...
| | #1 |
| Are stroker kits worth the money? I know that's a very broad question, but I'm just curious about what kind of gains can be expected? The main focus of this is for a h23a1. What are some sites that I should look into to gain more info on different stroker kits? Thanks |
| | #2 |
| bore and sleeve for cheaper instead and have a stronger bottom end. |
| | #3 |
| I was toying with the idea of increasing the bore AND the stroke. As usual, I've got too many projects going at one time, so I'm a long ways off from reaching my goals, but just looking for some info so I can be better educated when the finances are there. |
| | #4 |
| a stroker kit really isnt worth it as an entry level mod it will help but you will only truely see the benefits on a fully built engine so unless everything else is in the works as well dont bother for now |
| | #5 |
| I'm writing up a contract on a house today, so If that works out, I'll be driving me prelude as is for quite some time. However, If it falls through I'm lookin at doing a Full build on the engine. If the engine is out of the car and being built, I'm guessing it would make the most sense to do a stroker kit at the same time as the rest of the work rather than pull the engine again later on down the road. (correct me if I'm wrong) What exactly is included in most stroker kits? I think its a new crank, rods, pistons, rings. Is there other stuff too? What kind of money are we talkin about for a H series stroker kit and what kind of gains could I count on if the rest of the engine was fully built. This car is a pleasure only vehicle. I drive it at most 3-5 times a month. (just to help you understand my goals) What are some companies that make stroker kits for h series engines? Thanks for all the help!
__________________ Now accepting applications for "Female Friend with Benefits " |
| | #6 |
| Try www.pacmotorsports.com these guys do the stroking. However I wouldnt suggest stroking a prelude engine. "The walls are thin" Anyways, if you wanna see some power then i suggest you sleeve it, bulletproof it and turbocharge it. Youll get the most bang for your buck. Escpecially if youre just a sunday driver. You could also try lhtperformance.net Good Luck!! PS youre lookin at probably 4 large for a stroking. |
| | #7 |
| I agree with pills & Esol Milan |
Similar Threads | ||||
| Is Skunk2 cams shafts worth the money? | Teambypass | HYBRID -> EG-EK / DC | 4 | 09-23-2003 11:08 AM |
| Stroker Kits? | 93tegh22 | Engine Building | 0 | 05-06-2003 09:25 PM |
| Crower Stroker Kits | EdrikLongtail | Engine Building | 18 | 04-28-2003 07:22 PM |
| Stroker Kits | civic_ferio | General Tech and Maintenance | 9 | 04-06-2003 11:31 PM |
| Stroker Kits For B16a? | disamis | Engine Building | 14 | 03-28-2003 03:20 PM |
