Swap /Building B18 need info HELP!
Old 06-02-2004, 11:13 PM   #1
Rep Power: 12 Boosted4dr is off the scale
As of right now i am trying to find an engine for my 4dr 1992 honda civic ex... it has a turbo in it right now on stock d16z6 ( For Fun ) no other engine mods done except HKS Hyperformace exaust and High flow Cat. ..
i am sure that i want to go the the b18 bottom end cause it has good displacement...
now the question between heads is keep the head stock or use the b16 head. Build up the motor and head to be low compression with a t3/t04e which is currently on my car, Or go high compression with Individual Throttle bodies
There is 3 quesions that are going back and forth in my head... but my goal is Power, cause well i like to drag and the sohc d16 isn't cutting it
if you could let me know what you think that would be great, Thanks Boosted4dr
Boosted4dr is offline   Reply With Quote
